Sprung over?
Zaw16
Jessup
Pa
I have a 1982 scrambler it has 4 inch lift springs and 1.5 inch shackles. I want to spring it over. What do I have to change and whAt axles would you guys recommend
I'm new to this please help me out. Thanks zack
With the 4 inch springs and shackles, you are going to have about a 10 inch lift, and be able to run 38 in tires. Thats a pretty big lift. I ran that setup on my CJ7 for offroad. Is that how high you really want to go?
If so, minimum should be dana 44's, rear Ford 9in, or one tons. You will need front/rear driveshafts, maybe a rear CV shaft, shocks, brake lines, steering, etc.
4" lift, 1.5" shackles and sprung over is huge! What tires do you plan on running???
Here is my Jeep... 2" springs, stock length shackles, spring over. 37" tires.
Yes I would like to go that high. I was considering 1 tons. But what would I have to change to steering
First, welcome :wave:
Second, not to be annoying, but my recommendation is to do A LOT of reading before you get into anything like this. Posting this thread and asking for input will only get you so much. Going spring over will take all of the things listed above and then some. You need to go out and search for the information and read like mad. You can ask specific questions you come across, but you'll need to figure out most of your own plan.
Third, I'll say that the current "trend" is to lower centers of gravity with as little lift as possible but with other mods (flat fenders, fender cutting, etc) to fit larger tires. People are realizing that all that height is really only beneficial in deep mud bogging and that street driving or trail riding/rocks are better handled by the lowest COG possible. JP Magazine even went so far as to say that they thought they'd done their last spring over, preferring to go with spring under simplicity and other mods/cutting to go to big tires.
Just my :twocents:
Once you get the suspension done, do the steering last. Probably pitman arm and drag link, maybe high steer.
Zaw, I'm going to say what a bunch of guys are probably thinking: "If you're asking these questions, you're really about to get in over your head." If you're new to this - unless you've got a TON of experience fab'ing in other categories, e.g. hot rods, etc... this is going to be a hugely frustrating and extremely expensive endeavor. You'll be paying people left and right for things you aren't sure you need... EVERYTHING from the steering column to the axles will be replaced - frame reinforced, spring hangers moved, wheelbase likely lengthened, steering box swapped, brakes swapped - from lines to booster/MC...
Most guys graduate up the tire chart - from 32s to 33s. to 35s... most stop at 35s... most don't need more than 33s. I have 35s... and "need" 32s. Starting with 10" of lift, SOA, and 1-Tons... well...
As others have said - spend a LOT of time reading. Google will be your friend here. Pirate 4x4 is treasure (like that pun) of knowledge. Oh, but don't ask questions there. They're not as nice... seriously.
Manhattan, thanks for your advice. so you would recomend keeping the same suspension setup and upgrading the axles?
I've had spring over axles (SOA) done. I'm on my second go around with SOA and it works great and rides great now. But the swap is not basic, it's not available with a kit and it's hard to get right. Most common problems are axle wrap, bad highway manners and stressed drivetrain. I've ended up with RE SOA 1.5" springs, MORE shackle reversal, MORE axle wrap bar and hi-steer linkage. All brackets under the frame are new (heavy duty) and have installed Jason's rear frame plates to help stiffen and protect the frame. My CJ-8 works well but still needs hydraulic assist, a better anti wrap bar. Tommy's bar he built works better than mine and his rear axle doesn't hop as bad as mine does (better geometry).
If you are going to one tons and beat on yours more than I do you problems will be harder to fix. If I were starting all over again I would go shackle reversal and leafs in the front and 4 link in the rear. The leafs will make it easier to stay stable without needing sway bars and the 4 link will eliminate wrap and also help wheel hop if set up properly. And as everyone has said basically SOA isn't easy or simple. My suggestion isn't easy either but may end up giving you a more capable vehicle.
What size tires are you looking to run and what do you want to do with the Jeep, let's start at the basics and go from there.
Yes. Assuming the suspension is solid (quality, in good shape, etc.). I might add a 1" body lift - but that's optional and depends on what tires you go with. 4" springs and 33s are a KILLER combination for a CJ7 or 8. Great look - matches the radius of the fenders (fills the wheel openings perfectly). The 33s aren't too much for the stock brakes. Upgrading the rear (Model 20) with one-piece shafts is about all you need to do, unless you really start 'wheeling hard.
Do you know what gears are in the axles? And, I'm assuming the 258 right? That's a great motor and plenty to turn 33s - especially if you've got 3.31s or 3.54s
Take a picture of the jeep for us - a good shot of the front end; shackles, spring hangers, etc. I'd probably swap the factory spring hangers for new... when you're ditching the 1.5" shackles. If those really are 3" over factory length - netting that 1.5" of lift... they've got to go! If they're 1.5" over stock - netting 3/4" of lift AND they're well made (braced, etc.) they're perfect for 4" springs.
We need pics!
i will get pictures up tommorrow, and bigwalton i would like to run 35s if i dont run the sprung over set up but with a dana 30 front rear and an amc 20 rear and an agressive set of 35's i can see promblems coming. i like to wheel with my current jeep(daily driver) so i wanted to better set up this jeep for the trails. to keep my other jeep on the road
There's no need for spring over with 35s. What you're proposing would be serious overkill for 35s and would likely look much too tall IMHO.
I run a Waggy HD20 rear and D44 front with an outboarded 4.5" Rubicon Express lift SUA, 1" body lift and 35s and it fits fine. The extra width of the Waggy axles keeps the tires out of the fenders in all but the most extreme flex and if I wanted to fix that a little trimming would work fine. The HD20 has a larger ring/pinion than a D44 and gets you one-piece axles and thicker tubes and they're EVERYWHERE for cheap. If your CJ20 has a locker, it will swap right over too.
With the larger brakes on the Waggy axles, you can upgrade the brake booster to a dual diaphragm unit and you'll have a perfectly streetable rig. There's off the shelf kits for outboarding the front springs or it's easy to do your own. Get one of the HD steering box mounts that moves the box forward 1.5" (I used one from MORE) and your pitman arm will clear the tie rod fine.
That's what I did, there's plenty of other axle combos out there that you could use for basically the same thing to run your 35s and have a great, reliable, and capable trail rig without all the hassle of SOA that's been mentioned or any links (makes SOA look pretty easy IMHO).
i want to run 35s if i dont do a spring over set up but i would like to run 37s with the spring over set up
Ok brother first off (correct me if I misread) you have 4" springs and you are currently getting 1.5" of lift from shackles? With that setup you should be able to run a 35-13.50-15 as I do with no rub. There is a picture of my Scrambler here https://www.cj-8.com/forum/showthread.php?t=34904. If this is your only goal do a shackle reverse to improve the way it handles. It will stop alot of the wandering and white knuckle driving although a soft compound mud tire will walk the road anyways.
Also, check your brake lines at full articulation. A common mistake is to check them on flat ground and then suddenly people find theirselves with no brakes on the trail.
Another option if you think the tires will be close, like a bogger tends to be wider, you may want to look into tube fenders as Bigwalton said. Cheaper than a lift and keeps COG low. But remember, a real wide tire without the proper backspacing(and sometime with) will most likely rub the spring at full lock.
This is just a start to the endless possibilities.
So, like everyone has already said, do some reading and first decide exactly what kind of wheeling your gonna do. Most jeeps with 35's and lockers will go most anywhere if your an experienced driver IMHO!
Don't forget to ask questions! You may get some real jackass answers and some people think they know everything, but it doesn't hurt to ask.
