So awesome! So how do you feel the T-5 did overall? Any regrets going with the 33's over the 35's? Other than welding the axle tubes, any other things you would change or do differently on your build?
Appreciate it, it was an excellent trip/adventure
As far as the T5 goes, I think it did great overall. I really like the ratios, and the B&M shifter makes all the shifts short and positive. I had no issues with the T5 whatsoever on this trip. It performed great on and off road. Even the overdrive, which I thought might be "too deep" at first, worked out well. With 33" tires, 4.10 gears, and the MPI equipped 258, I was turning around 2,300 RPM at 70 mph, right in the "powerband". Now, I did have to shift out of 5th into 4th on the steeper/longer grades in the mountains, but a "shallower" over drive would not have prevented this. For how I drive my Scrambler/how it is set up, I think the T5 should hold up for awhile. With that being said, I know the T5 does not have the best reputation. And, after rebuilding various transmissions, I do know the T5 is definitely on the "light" side compared to other truck transmissions. But, since all my internals were in excellent shape, the case was in excellent shape, and I completely rebuilt the thing to factory spec, I am thinking that my T5 should hold up for quite awhile. I do believe that I am at the "upper limits" of the T5's reliabiltiy range, but treated with respect, I am thinking it should hold up fine. To sum it up, I did not bring my spare T5 with me
As for the 33" vs 35" tire size, I am very happy with the 33" tires. The vehicle feels more stable (on and off road), the smaller 33" tires feel less "taxing" on the rest of the powertrain, the on and off road performance is much better with the 33" tires, and it is easier to get in and out of the vehicle. For how my vehicle is set up, to drive equally well on and off road, the 33" tires are a better choice for me
The few times that I got stuck/hung up/had to winch, 35" tires would not have prevented these occurances. I will be sticking with 33" tires on this Scrambler. And besides, I just drove cross country and back, plus tackled some of the toughest trails Moab has to offer while on 33" tires, I see no reason to "upgrade" to larger tires on this Scrambler
As far as changing anything on this build, nope, I am very happy with how this Scrambler performs. It feels very "balanced". It performs equally well on road and off road, which is what I wanted. When you think about it, this Scrambler is pretty much "stock", with upgrades where I thought they were needed to the factory components. And for being close to "stock", it performs very well. There are always compromises to be made when building a "dual" role vehicle, but so far, I am very happy with this Scrambler's performance. I really do not want to change anything major on it. I might add on board air, but other then that, I can't think of anything that I would want to change on this vehicle. The way it sits now, it puts a smile on my face everytime I get behind the wheel, which is what it is all about
And besides, I have a V8 powered/auto transmission equipped Scrambler sitting in a warehouse in Baton Rouge that I still need to get running. I might swap some "60's" under it and run some larger tires on that one. After driving that one, maybe we will see if I still feel the same about my red Scrambler
