mysunnshine
- Phoenix
- AZ
You will want to keep the factory regulator. I would not replace it unless it is leaking.
So are you going to have that thing done by the end of July? I'm going to spend a few days up in and around Sedona again like last year. Maybe we can get together and hit some trails...
Great looking build. The 'Vette filter/regulator is the ticket if you don't have the rail mounted regulator. I think only Flex-Fuel 5.3's used the rail mounted regulator in '04.
As far as wheels/tires go, I think with the Bushwacker flares a set of 35" on 10" wheels would fill out the fender openings nicely. I suggest 10" wheels because with 8" the tires look too "tucked in" on the flares. I have 8" with 35" tires on mine, but I am also running a 60" wide axle. I think 33" look too small with those flares. Same lift as yours. Bunch of pics in my build thread.
Maybe I missed it- what's your gearing? I run 4.56 in mine and I am really pleased, my trans is an auto (4L60E) but the overdrive is similar.
I like both the wheel choices. 16" or 17"...either one's good. 15" is going the way of the dinosaur.
Yeah, I got into my rear fender a bit, going to have to do some trimming. I thought the Bushwackers required fender trimming? I still think 35" would look better, but 33" might not require the trim. Keep an eye on Craigslist- there's always someone with a set of baldies that they'll sell for a few bucks. Mount a few up and see what you like best.
can you please post a pic of how and where you mounted your computer?
Looks awesome!! Cant wait to roll mine out of the garage!!!
This build is awesome. Get rid of that "mechanical novice" BS.
