Thanks everyone for the thoughts and prayers. It has been very much appreciated. It has been a tough month but things are starting to move on. I packed up my mom and brought her out to Arizona with me after the funeral so things have been busy. I did get back on to working the Jeep this weekend with my brother-in-law though.
So I was thinking I should drive the Scrambler to work this week, if I could get some front fender flares installed to protect the paint job. Of course, it needed some test drives this weekend to see if it would be road worthy, and my brother-in-law is a much tougher test driver than I. So, after a few nice drives he dropped it in 4-lo, stepped on the gas and BANG
Yeah, I figured the driveshaft blew up. Was pretty sure I had it torqued on the leashes and C-V Joint. Well, somehow it blew out of the leashes on the rear axle yoke.
So, the rebuilt Scrambler got it's first tow home. When pushing it up in my driveway, I noticed the rear axle had ~15 degrees of forward to backward play in it. I think I know what could have been the problem. When checking the u-bolts on the rear axle, they were not torqued up to the 85 ft-lbs I had thought I put them to 10 months ago or so.
Well, just tighten them down and that should be okay, I thought. This is all part of the learning process. I next found that the axle perches for the leaf spring were now rounded. Oh yeah, when I was cleaning up the axles those perches in the rear were full of dirt and rust, and I did clean that all out, but I never thought about the fact they would no longer have strength. Oops. Gonna have to fix that one.
Any ideas on heavy duty perches to weld onto the axle housing? The angled piece that fits between the spring and perch got cracked too, but I figure the new perches can be welded on in a position that renders them useless anyhow.
Also, noticed a little chunk of the rear yoke was blown off in the initial incident, the little piece that helps align the one side of the u-joint. Got a new one on order with u-bolts instead of leashes to hold the u-joint in this time.
I am thinking the boaty feel of the drive was in large part due to the loose rear end. Hopefully it was.
Despite all the issues, I still think I will drive it, slowly, in to work tomorrow. It is about a 3 mile drive, should be able to handle that, and we'll see what else happens.
