Where alaskan postals go for vacation!!
The museum one is beautiful, If I go off of that one I still have a lot of original parts on mine. I even still have all four jeep mud flaps.
Even that one doesn't have the spare tire rack, did they really come with one? And if they did, anyone have any pictures?
I really would like to see the museum in person but it's a tough drive from here....might need a snorkel..
I've never seen one around here that's ever had a tire rack on it.
I have never seen a postal with the tire rack. The only thing I can think of that wasn't the same with all of them was the auxiliary gas fired heater that they put in the ones that went farther north. The one in the MATI has it and you can see the sign on the postal tray about letting it cool before refueling (I assume due to the possibility of fumes igniting under the Jeep), the heater was mounted outside the frame rail near the rear of the Jeep, in front of the gas tank, or at least I think that's where the one on the MATI postal was.
Did you check out my crappy, old web page with pictures and the documentation on the one that was donated to the MATI that explains about the postals, the number of them, etc? I have more pictures of the restored one there.
http://www.kateanderic.com/postal/postalmain.html
Ugh, I really need to pull all of that info into an article here.... embarrassingly bad :banghead:
Don't feel bad about not having the info on this site, at least its out there and in one spot.
Jeff Scherb mentioned it on his web page. I don't know..or he was talking about the Overlanders.
http://home.roadrunner.com/~jscherb/scrambler/spare.htm
Anyway, I will just make my own. I've had some good practice rebuilding my wife's CJ7 so now I will apply
it all to the AK8. I'm going to try and do the 4.0 swap this weekend, we'll see how that works out.
Gotta talk Grandma into watching the kids.
That's applicable for Overlanders. He's using "Alaskan Postal Top" in lieu of "World Cab" or he could have said "Overlanders were originally equipped...."
Details man!! What 4.0 are you using? How are you going to do the clutch setup on the manual tranny from the right? We need details! And pics!! :D
I've got a buddy who did a T-176 into one using a hydraulic clutch, but I never asked him about the swing-pedal assembly. I know of another one up here that's getting a 4.0 swapped in (and has been "in process" for probably two years, but it'll be a really nice Jeep when it's finally done).
Don't worry, I will bringith the pictures...
I'm using a 94' Cherokee Sport engine with the AX15/Dana 300. I grabbed a brake/clutch pedal set up out of a 7 and using the hydraulic clutch from a Wrangler.
The line from master to slave is just long enough to work. I'll go into more detail later with pics..
