Mercedes OM617 diesel swap???
Kane
Berlin
ct
I recently learned about the Mercedes OM617 5 cylinder diesel motor that came in the early 80s cars and while researching I found a company that makes adapters to GM transmissions. This is a fully machanical motor that only has 6 wires to hook it up and really only needs three of them in a conversion. The HP and torque out of the box are not very large (similar to the 258) but the turbo can be tuned to make some pretty good numbers. I found a person that did a swap into a CJ7 and he is getting almost 23mpg and with a lift and large tires.
Does anyone have any experience with this motor from either owning or working on the Mercedes vehicles?
Here is the link to the company that makes the conversions adapters.
http://www.4x4labs.com/
I was seriously considering this for my Scrambler. Then I decided to swap in a 5.3L Vortec.
I wanted the power since I dont drive the Jeep for fuel mileage.
I had plans for the LS swap as well and they do get decent mileage but this swap intrigued me by just the fact that it is diesel and not the 4bt.
Yeah, I didnt want a 4bt.
The LS swap can get good mileage, but its near impossible to get good mileage. Just too much fun to drive!!
I had my heart set on the 617, until i found my LM7. I still would love to have a diesel.
My CJ5 has a very strong 350 in it and I love to hammer the gas regularly when driving it. I only get aroung 10-12mpg but I love having fun. I would end up doing the same with the LS swap I am sure. I think the diesel would keep me in check and be fun to try and get power from a new style motor for me. Plus I want to use it for a daily summer driver. Tough choices but I have plenty of time before I get to the motor part of my build. I have at least another 6-9 months to go on everything else.
I daily drive the Scrambler in the summer with the LM7. So far average mileage is 11-12. But that was alot of towing and off-roading. Best tank was 16mpg, wife was driving, all highway doing 75mph.
Worst tank, 9mpg, Silver Lake Sand Dunes.
I have a heavy foot.
probably be worse next summer, swapping in a different cam shaft... more bottom end torque.
I too have researched this swap. Met a guy at. Olympic 4x4 in Snohomish who has a Cj8 with the Mercedes and a 700r4 trans. He reports on the road milage in the high twentys. He has a loMax 4:1 in the dana 300. He said the low 1st gear and the overdrive made this combination a dream to drive.
This is not a cheap conversion. You have to buy both engine to transmission and transmission to transfercase adapters.
I am a bit ahead as i have the 700r4 and adapter to the Dana 300 and the adapter to bolt to the 258. Since my 258 only has 27,000 original miles. I am not sure what way to go. What's' a low mileage 258 worth?
I wanted a NV4500 (which is what I have now) as I'm not a fan of automatic. So I would have had to buy adapters for everything too
I have no idea what a low mileage 258 is worth. They are of no use to me, but it might be to someone. Personally, Id rebuild an engine before buying a used one. But thats just me.
16mpg on those huge tires is pretty damn good and alot better than a new wrangler with the same tire size. I would be rolling on 33's so it would be a little better.
You didnt want a cummins because of the noise???
Not squat when you figure out how much you have to spend on a diesel swap.... I have two of them sitting in my shop I cant seem to give away.
Here you go.
http://www.mercedesdiesel4x4.com/
Guy has all sorts of kits that will let you put the Merceds Diesel in the Jeep and keep using your existing transmission. Great way to make an off the grid Jeep. No Computer.
Carl
Wait, which one of you jumped it at the dunes?? ;)
Connie jumped it first... But I jumped it too... remember? I was driving right beside you when the front end was 5ish feet off the ground!!
didnt want cummins because of weight, noise...
but those were not the main reasons.
prefered 617 for:
reliability, parts accessibility (there are a billion of them everywhere in the world), and I'm German so i'm a little partial.
The LS won, because I am a hot rodder, nothing I own is un-modified. I like to drive fast, and since I dont have the room for a fast car, the Jeep has to be a jack of all trades. AND, I got a good deal on the engine so I couldnt pass it up.
I just put an OM617 in my 84 Scrambler last month (Jan 2013), and so far I am quite pleased with the results. It's not going to win any drag races, but up here in Colorado at 9500', the turbo spools up and and makes the posted power settings. The 4.2 was quite lacking up here. It is definitely a high revving engine. I have done Cummins swaps and VW swaps into suzukis, and this one is certainly different than all of the rest. It is a short stroke diesel, with a sweet spot at about 2400-2600 depending on who you talk to. That takes some getting used to. This engine redlines at 5000 rpm with max horsepower at about 4500-4800 rpm. My jeep will reach highway speeds in 3rd gear. The turbo isn't happy until well over 2000 rpm. Once you get used to these traits, it's actually pretty fun to drive. You are constantly revved up with power in reserve. I drive it all the time, even when I don't need to. (I have my diesel Jetta for the daily stuff). Very cool swap, and I did it for about 2500$ out the door. My cummins swaps exceeded 12000$, mostly because of the gearing and tranny stuff you have to do to keep that engine at 1800 rpms. Anyway, this was a very fun swap, and cheap. Not to mention that these engines will outlast you.
Cheers
Greg
BTW, this swap favors the stock 4 speed tranny. I have spoken to guys who have swapped in the AX 15, and the Merc just doesn't like it. It smokes and bogs down, asking you to rev higher. Another reason that this is a cheap swap. Just bolt it to the CJ tranny, and go have fun.
Cheers
Greg
Good info. A coworker of mine is really pushing me to do this swap as well. He is a diesel nut from Poland and knows the OM617 inside and out. I would have a great resourse from him. So I take it you ran a four speed manual in yours?
Did you take any pictures of the motor in your Jeep? Did it weight the front springs down at all? I think that motor is a couple hundred pounds more than the 258.
Yes, I have the T176. Works fine. Highway speeds no problem. Just have to get used to that diesel revving the way it does.
It is heavier, but did not push the front down at all.
