For a V-8 with 33" tires and no overdrive, 3.73 is ideal. But with overdrive, I'd go 4.10.Not what I wanted to see when I pulled the pinion gear out of the Dana 44 rear end. I guess I have a choice to make at this point. I can just buy some new rear gears in the same ratio which is 3.73-1 or go lower in both axles.
I learn a ton on this portion of the project and hope to get better at painting over the winter with all the other parts that need to be done.
I spoke too soon, looks great with the new color.
Remember though, here in New England... painting in the winter is not a lot of fun. The paint, the metal parts, the air, etc. all have to be the same termperature... "warm" and that is hard to do unless you have a good heater. I ran drips all over last year trying to paint and ended up waiting until it warmed some more to get the rest done.
Good luck with the reassembly!
Ditto the comments above. Colour is cool as is all of your hard work. Paint is a blast isn't it? I made mistakes on my 10 and can't wait to do my next paint job. It's going to be another JK colour, Dune. How any base coats then clears did you use?
