Longtime Fan
Oh yea. Just adding in the big stuff:
Body Work: $2300 for blasting/priming + $3400 for paint/rust repairs/liner
Makes the price of an Aluminum aftermarket tub look pretty good....
Wheelin with an aluminum tub would make me nervous. I bump into way too many things when I'm off road (which makes fiberglass out of the question).
The aluminum tubs are stronger than steel. My tub is 1/8" thick.
A strength-equivalent aluminum structure will require 50% greater plate thickness than steel. For exampl, aluminum with 1-1/2" plate thickness offers equal rigidity of construction as 1" steel plate thickness. So, if aftermarket aluminum bodies are 1/8" thick, how thick are the standard steel bodies?
BTW, I read that Ford's new half-ton truck bodies will soon be constructed of aluminum, as opposed to steel. This design change is being implemented in an effort to achieve future compliance with government fuel economy mandates.
Also a lot of supercars use aluminum for the entire substructure and body of the car. Not to mention the aircraft I fly are all aluminum.
Yep, aluminum has the advantage of being lighter-in-weight than steel, while still maintaining structural integrity. Being a non-ferrous metal is an added bonus, unless you subject it to a lot of salt. Some exotic/super/fast cars, like the premium Corvette models, also use other interesting alternatives to steel or aluminum in some or most body components. I think Ford has a good idea (especially for rust-belt buyers), but I think the price of aluminum will dictate how well the new truck bodies are received.
Better than steel or aluminum:
forum
In a year, won't that copper Cobra be green like the Statue of Liberty ir the one on top of the US Capitol? But it is sweet. Reminds me of that Audi A8 that was made o silver. Just to do it. That thing must have been heavy though.
Plus you can travel back in time and buy a few of the '86 Scamblers:thumbsup:
Geez, if people could travel back in time, there would be so many Scrambler models snatched up that the CJ8 would probably still be manufactured today, and AMC would likely still be making them! :)
I'd hate to drive that Cobra with 100 miles of a thunderstorm storm! I love the way these conversations take on a mind of thier own :thumbsup:
It takes an 1/8" of aluminum to equal the strength 16GA steel. In spite of that the aluminum is still much lighter.
Here's why I'm not interested in an aluminum tub: Corrosion is a serious issue for both metals. Especially for off road vehicles. You get moisture in places that are generally not an issue with road only vehilces. Aluminum is more resistant to corrosion up to a point. Once you reach that point it litterally turns to dust. Structural failure is catastrophic. Steel shows rust faster but the resulting structural failure takes longer. Aluminum will not stretch as far as steel without cracking. A hit on steel body panel producing a significant dent is likely to split the aluminum counterpart wide open. Both metals have thier uses. IMHO a jeep tub (for serious off road use) is simply not a good aplication for aluminum.
Aqualu makes tubs out of 5052 marine-grade aluminum, and claims they are 60% stronger than OEM tubs. Have you seen how many aluminum-bodied buggies are running around Johnson Valley during KOH? I spoke to a guy who rolled a CJ-2A buggy (tube frame, coils; only an Aqualu body and aftermarket grill even made it resemble a Jeep) down a cliff and put a major dent above the right rear fender. He said they pounded it out, did a light sanding and repolished that area, and from 15' away I couldn't tell it had ever been hurt.
I live in Alaska, where 85% of the skiffs running around in the ocean are made of aluminum. While I've been careful to coat areas that need to be coated and am keeping exposed areas polished, I'm not super-worried about corrosion. Plus, you can always just paint the whole thing.
