Back to basics... thinking through why I may not getting a start.
battery is good
fuel and fuel pressure are good
signal to the fuel injectors has been verified by noid light/tester
I just did a dry quckie compression test (on a cold and newly rebuilt motor) and got 110lbs quickly built on #2 cylinder
I've verified that I'm getting spark at a spark plug
I've verified (I think) that my TDC and timing are set at 0: air pressure at #1 spark plug hole, timing mark at 0, rotor at 1, and piston at the top of its travel.. this is one area I'll definitely check and re-check again...
I pulled three of the (brand new) spark plugs.. one appeared to be covered in sort of a wet/black soot, the next two appeared to be bone dry (shortly after multiple attempts to start the engine).. no wetness, no gas smell, could be a sign that only that one plug is getting fuel?
- when I was purging the fuel pressure gauge, I did get some dark fuel out of it (all the fuel is fresh, so it must have been cleaning the bottom of the (previously cleaned out) fuel tank and the rust/dust out of the fuel lines which have sat dry for over a year mounted in place
things that I'm thinking may be the culprit:
- timing: as stated, I'll re-check
- actual injectors: these are the original injectors from before I rebuilt the engine, which ran fine before I rebuilt it.. unless the initial purge of rust/dirt from the dry fuel lines clogged up all 6 of them, I'm not sure how they could all be bad.. that said, I'm surprised after all the start attempts that i've got dry plugs coming out of the cylinders..
- a ground somewhere in the system.. maybe something to do with NSS or park sensor. I've grounded what I think may need it, but not sure if I've overlooked one, or perhaps did one wrong. If I did miss a ground, would it still allow me signal to the injectors and start signal to the starter? I'm thinking those would be interrupted?
I like to learn, but this is getting to be a PITA.
