HOLY &*^% Ultimate Apocalypse/Zombie Survival Vehicle!
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
:drool: :drool: :drool:
http://atlanta.craigslist.org/atl/cto/3748633581.html
---TATRA T-815 (8x8 Wheel Drive) --- "Expedition Vehicle" / R.V. Conversion ----- 9,800 miles
(909) 798-1136---------------------$59,000.00
V12 Twin Turbo Charged, Air-Cooled Multifuel Engine. This 8x8 Wheel Drive vehicle has a towing capacity of 200,000lbs. Perfect running condition - Only has 9,800 miles on the clock. Not even run in.
This military vehicle was said to have been captured in "Operation Desert Storm". This partial complete "R.V. Conversion project vehicle is for the "Adventurer Who Dares to Build Their Dream Vehicle".
DETAILS of CUSTOM PROJECT
CUSTOMIZED: FROM "CARGO-TRUCK" to "R.V"
* CHASSIS MODIFICATION - CUSTOM: Truck has been extended by additional 5ft
* "SLIDE OUTS" - CUSTOM: Fitted with 2-Custom 12ft opposing hydraulic Slide Outs (Hydraulic Pump and all fittings are available but not yet hooked up)
* "SUNDECK" - CUSTOM: A custom fold down "Sun Deck" is located on the Right Rear Side of the vehicle. When folded up (Closed) the "Sun-Deck" seals off the Door Entry Way for added security. When "Sun-Deck" is folded down, you can access the "Tilt-Up-Roof" for the Sun-Deck. The "Sun Deck" roof framing has been pressure tested to accommodate water mist sprayers for additional outdoor relaxation and comfort.
* "ROOF SEATING AREA" - CUSTOM: A roof seating area is located on top of the cab roof and is accessible by stairway leading up from the RV living Area.
* "OBSERVATION DECK" - CUSTOM: Is located on the roof and accessible by stairway leading up from the RV living Area.
* "STORAGE AREA" - CUSTOM: At the rear of the vehicle is a lockable tilt up lift gate to access additional storage area. Perfect for propane tanks and drinking water filtration systems. The "Sun-Deck" railings are configured to be stored in the lift gates frame work.
* WATER & FUEL STORAGE AREA - CUSTOM: Behind the rear wheels of the vehicle and situated in the frame chassis, is an area allocated to add additional fuel and water tanks. Heavy structural design with 1/4" plating to protect tanks. Note: Tanks need to be fabricated - not included.
* TOW HITCH - CUSTOM: The original complex tow hitch system mounted, on the truck, was removed and relocated into the new heavy duty rear bumper system.
* AIR PURIFICATION: In the rear of the cab is a "Chemical Warfare Air Purification" System which feeds 8-gas masks.
* TIRE INFLATION SYSTEM: Tires can be inflated or pressure dropped from inside the cab (Similar to Military Humvee's)
* HYDRAULIC WINCH: Is located under the mid section chassis and cables can be routed to the front or rear of the vehicle. This is controlled from the cab area
* WORKSHOP MANUALS: Owner & parts manual is included.
* TOOLS: A variety of tools is included along with gas masks and some spare emergency parts.
At this point the project requires to be cladded on the outside. All interior & exterior plywood paneling has been tailor cut, treated and ready for installation. The outside "Sheet Metal Cladding" has been cut and bent to size and shape and ready for installation - included in price. Note that Hydraulic pump & equipment for the 2-slide outs (12'wide) is available for this project but not included in the above sale price. This also applies to the hydraulic pump system and 4-heavy duty self leveling jacks that are available for the vehicle.
Note that a custom built trailer has also been built for this project. It has additional steel fuel tanks, S/S tanks for water - All this is fabricated into the floor. Not included in the sale of the TATRA T-815.
---------- 9,800 Miles (Not Run In Yet)
---------- V-12 (Multi-Fuel Engine)
---------- Twin Turbo Charged
---------- Air Cooled
---------- 355HP
* VEHICLE CURB WEIGHT:
---------- 36,000lbs
* LOAD CARRYING CAPACITY:
---------- On Bed: 20,680 Lbs
---------- Tow Weight: 220,000 Lbs
* TRACTION:
---------- Full Time 8x8 Drive
---------- Moment Torque Axle Divider
---------- Differential Locks
CONTACT: (909) 798-1136
Gas masks for 8!!!
What, no weapons mounts????? Best way to fight a zombie invasion is by not leaving your vehicle... Especially since the mileage is probably so bad that even with all the extra tanks you might find it hard to even leave the town you're in.
You don't have a hair on your ____ if that thing isn't towing the Scrambler to the National this year!
What's the towing capacity?
Oh, there it is...220,000 lbs. That should git er done.
wow.
Have to say I have not seen one of those on Craigslist before.
The HOA would love seeing that parked in front of my house. Woot!
