brake help with rear discs
scsbccj8
oregon city
or
ok i have read and read until my eyes hurt. for some reason i am having an issue on the scrambler with the brakes and i want to upgrade. i have read all the upgrades and all the options but i want to hear from people that have used the parts. what, if any, proportioning valve did you change to for rear discs? what master cylinder is a good upgrade? Caddy? Vette? what about a bolt in power booster upgrade. i have power brakes already but want to upgrade without spending the money on a Navajo system. so who has what and what do they like/dislike? what modifications, if any, did you have to make to make it all fit.
thanks in advance.
corvette MC astro van hyd booster. Wilwood adjustable PV completely eliminate stock PV
So you have to change the brass junction block thing? (I think that's the proportion king valve)
As suggested on a diffrent thread somewhere you need something like this:
http://www.jegs.com/i/Wilwood/950/260-11179/10002/-1
And that replaces the standard proportioning valve which you can put in the scrap bin :D
As a bonus the bolt holes will hopefully line up with the ones already in your frame if you are lucky.
Anyone have any pics of there setup? I will be changing mine soonalso and haven't heard of or seen this PV
I'm sure I'll get flamed for this, but honestly I think rear disks are over rated. They don't really stop you any better than drums. The only real improvements are; 1) easier to replace pads than shoes, and 2) if you drive in the mud a lot, the disks will self clean faster than a drum. If your issue is stopping in normal driving conditions (oversize tires will burden an already somewhat weak CJ brake system), I'd just replace the stock power booster with a dual diaphragm booster or a hydro brake and call it good (save yourself 5-6 hundred bucks).
Just my opinion, others will vary.
I went to discs due to the cost of getting j20 brake parts out in Australia was pretty much the Same price as doing the disc conversion. Ps I have a Handbrake that works.
2 drums was roughly $600 aud locally and about $500 shipped aud from the us. Then shoes and cables- I got my whole disc setup owing me $700. That's glo e brake kit, rotors and lokar handbrake cable kit.
I agree with you Spieg Drums are brilliant for road use, but for off road use as soon as you get mud in them, they just eat themselves and implode.
A new set of shoes everytime i went off roading made me swap to discs on the rear, and they do at least make a bit of effort stopping you when wet.
So maybe i should stay out of the mud? :D
I did 4 wheel discs on my Scrambler. Seemed better but not a ton. I did Hydro Boost on my CJ7 as I did not have a lot of vacuum due to the cam. Night and day difference I would do Hydro All day long. Prop valve will not make your brakes better the way I understand it. I did the Vanco Hydro Boost
I am converting to disk but not for the hopes of more power. I want the benefit of a lighter rear axle. I also have a scout rear end and the new drums are very pricy and hard to find. I am doing my own disk conversion for just $200 which was the price of one drum.
I am doing my own disk conversion for just $200.
$200 is an awesome price for a total conversion (even for junk yard parts). Can you share your parts list and installation tips? I think that was the point of the thread to begin with...
Use Google and you will find a bunch of threads using Maxima and 300Z rear calipers with Sidekick rotors. Diagrams of the bracelets included.
Here's a question:
With the cover of the master cylinder, when I push the pedal down, the front reservoir spurts like mount Olympus yet the rear doesn't. I have to push gently to get it to kinda bubble then push moderately harder. Is this normal? Or do I have a stuck piston or something?
Here's a question:
I think it's normal for the front reservoir to squirt more than the rear. Wouldn't think the piston is stuck, although it's possible one of the seals is worn.
I used 1998 suzuki sidekick 4 door front rotors and 1987 nissan 300zx calipers. I made my own mounting bracket for free. I made it out of plastic then transferred the measurements to a cad drawing and had a buddy waterjet the brackets out of 3/8 steel. The rotor needed the bolt holes reemed slightly and then it was a bolt on affair for everything. A bracket needs to be welded to the axle tube for theemergency brake cable mount. I have not done this part yet since my conversion is part of a whole restoration. The only change up front that needs to ba made is the residual valve that is normally 10lb for the drums needs to be changed to a 2lb for the disk. I have pictures of what i have done so far in my build thread if you want to see the calipers mounted to the axles.
The rears don't squirt. They don't do anything!
No there should not be enough fluid coming back to create a fountain.
Some will come back but i wouldn't of thought it would be noticeable as you don't shift that much fluid pressing the brakes.
Is this all new stuff or has it been working?
If its piped up properly then maybe you have not bled it properly and when you press the pedal you are compressing the air thats in the lines and calipers and then when you release the pedal its springing the fluid back (this would be worse if you pumped the pedal as you are compressing it even more!).
