RE 4.5" Shackles Tweaked?
FlagJeep
Flagstaff
az
I noticed and have gotten a couple of comments from others that my shackles appeared to be a bit pigeon-toed. I am not sure why this is, the rear leaf spring mount is still the original piece on the frame and everything up front is tight, but it does definitely look like the springs are not lined up straight with the rest of the vehicle. I think it looks consistently pigeon-toed on each side, which makes me wonder if I installed something wrong here or if this is just how they typically look?
Any thoughts, anyone?
Need a closer up image?
i would post a head on picture taken from a lower position
It is really hard to tell (post a larger picture) , are the shackles bent at the top? almost looks like the wrong bushings were used at the top and the shackles were pulled in .
2" top - 2.5" bottom for YJ width front springs
That's pretty normal for the RE shackles, from what I've seen (on mine too). You can make it better by replacing the bushings. If it's really off, you can loosen the u-bolts, pull the springs into place straighter and re-tighten the u-bolts.
20130823_082153-400.jpg20130823_082157-400.jpg20130823_082203-400.jpg20130823_082208-400.jpg
John N - That was what I was wondering. I plan on putting some additional bump stop on the axle, and they go under the u-bolt on the axle anyways so I was planning on loosening the u-bolts and seeing if I could straighten them any. They don't appear to me to be bending/breaking.
Here are a few more pics for the rest of the group, hopefully they are more helpful. I can go out and take a lower angle picture with both shackles included if that would seem to help. Not sure that they are all the right angle, but it should work if you turn your head sideways when looking at the computer :banghead:
Thanks
Have you replaced the bushings on the frame side at some point in time recently?
Not any more recently than the rest of the Jeep. Put the lift kit on all together and the Scrambler has under 2k miles, maybe under 1k miles, since the whole restomodification project started.
I did check to see if maybe the original frame and its rust had compromised the mount and caused any bending, cracking, etc... where the spring mounts to the frame but it appeared to still be stout and uncompromised.
A buddy of mine had the same problem and was never able to resolve it. When I put in my YJ springs, I also installed new YJ shackles and shackle hangers. It worked great and my friend ended up copying my setup.
http://www.mountainoffroad.com/_e/CJ_YJ_Spring_Shackle_Hangers/product/7686FSH-25-YJ/7686_FSH_2_5_YJ_Front_Shackle_Hanger.htm
http://www.jeep4x4center.com/rear-shackle-lift-0-greaseable-warrior-war13220.html
By using rear shackles in the front, the offset brace allows space for larger military wrap springs (actually mounted them upside down) without going to an even longer shackle (these are 4" hole to hole).
This seems to be normal for CJ's. Mine had it too- after measuring my bare frame, it turns out the frame "pinches" in at the rear spring mount making the front shackles splay out. Ever removed your skid plate and had a hard time reinstalling it? When I built my new skid, I made some braces that allowed me to push my frame back out to even and keep it there.
That makes sense. I would guess the bigger springs and taller shackles accent what is already there.
Part of the problem is the length of the RE shackles. They cause the front axle to shift side to side. On YJs Jeep went to a track bar to fix the problem. I have found that even Jeeps with every part new on the front end and steering will have some wander or slop in the steering due to the springs or shackles allowing the front axle to move opposite of the frame side to side when steering.
