What did you do with your Scrambler today? September 2013 version
"Drove" my scram out of the garage for the first time in 2 years
Still no exhaust , creeped thru the yard in 4low with my daughter
Put the soft top back on. :( I'm not ready for summer to end, but for the last week the inside has been dripping wet every morning from the dew. And, and hour after I finished, we got a storm through here...1/2" hail, 60MPH winds, and about 2" of rain in an hour!
So just a typical day in the Pacific North West... :o ?
Actually, we have it pretty nice over here in Central Oregon.
However....
My wife drove the Scrambler to work today, because I need to install a trans cooler and trailer brake on her Cherokee (there's a new toy coming home tonite). It had rained all last night, and the drivers floorboard was about 1/2" deep in water...darn it, I forgot to put the drain hose back on the cowl vent.:rolleyes: (Last winter I had an aluminum plate blocking it off.) But even worse, the bottom edge of the dash was dripping water!!!:eek: The windshield gasket is leaking right from dead center above the media unit. It still works, but for how long. Time to reseal the windshield...:banghead:
Changed my dana 44 knucle because it was bent by a drunk driver that plowed into her..
Sent from my SPH-L900
Crawled under it to see if I could find where I am leaking gas. It is causing a puddly by the driver's side wheel. Did not find it but will take more time this weekend.
Dain
Built the 3 tap keezer. Part of a scrambler behind it. :)
I sold a sled of mine and had to deliver it.
Drove to go get some Shiner Bock to drink while I watch ATM BTHO bama!
started it up so landlord wouldn't have them hauled to crusher. Spare tub and top are being given the evil eye.
Crawled under it to see if I could tell where the fuel leak by the tank was coming from. I saw a frayed fuel hose. It looks like when the PO drilled the holes to mount the third row the drill rubbed the hose. I guess it finally started leaking years later. I taped it up temporarily to see if that was the spot. Then drove it around a bit. So far so good.
Dain
Frustrated by lack of parts to put rad fan back on today for the best Jeepin day of the fall ImageUploadedByTapatalk1379195485.564438.jpg
Installed early birthday present. New Omix front turn signals. They look great!! Much more even light reflected.
On a second note its shocking how bad the quality of the detects in the sockets for the 1157 bulb are. You almost couldn't tell there was any track there.
