Jeff's Offroad Build
Are you going to fuel inject the 512 or run it with a carb?
I am toying around the idea of FI the 383 I have and then adopt a shaker bubble setup to it... would be pretty unique I think.
The 'Cuda was a 383 car... auto with A/C when it rolled off the floor.
Will have a 5 speed and a 383 when we get it back together.
I have the original block with pop up pistons... unfortunately hard to get leaded gas now, so.... I have a replacement date coded block as mine is 60 over and I will use all the internals of the original that I can, new pistons, redo the heads and then fuel inject it.
PS> for all you Chevy stroker guys... go back to 1971 and read up on 383's ;) Just a little :evil:
ARandy how much more room do they provide once installed?
A ton up front- 35" tires, 4.5" lift, and I think I could fit 38"s or 40"s easy.
The rear is limited by the size of the factory wheelwell. 35" rub a bit at the front and back corners.
Let's see this Cuda, ;) got a picture? I really like any E body but the A bodies aren't bad.
It is a work in progress... need to get the motor done still and stabbed in... some quarter and trunk work.
Swapped in a Dana 60 with discs in the rear with Hotchkiss performance springs... sitting on OEM rallye wheels with new BFG rubber all around.
Shaker hood, gilled fenders, grille, chin spoilers, rear spoilier, new trunk lid are all ready to be put on and go to paint... just need to find money to do that and the interior needs to be redone.
Also forgot to mention I need $$ for the Alterkation setup up front so I can run coilovers and still fit discs under the 15" rallyes... so yeah, work in progress until I get more $$$$ to finish it. If I could just stop buying more Jeep projects, I could finish that!
That'll be a nice car when finished. I understand though, it's hard to find money for multiple projects. That's not considering other home projects like kitchen remodeling and deck rebuilding both of which I need to do!
Yea same here.. I got to buy a new gas boiler by winter. :( oil cost is to high.
Sent from my SPH-L900
I refer to it as a giant chess game, with cars, houses, yards, and wallets in play.
You have to move each one to a particular spot, do a little work, plan that something will go wrong, have a little cash for that, save for another inevitable, then move another car into the mix, do some work, all trying to keep to a budget per month and not spend too much.
So, usually the car gets moved out back to its spot, the water heater gets worked on, then the microwave is replaced.
Then you realized your new tractor that is going to be awesome to plow with doesn't have tire chains.
Then you order them.
Anyone know how f*&$ing expensive tire chains are? Good lord man! I have 3 sets but none would fit the rears... jsut my luck.... here they go CL!
Oh yeah, don't get me started on oil... 7 years ago, we redid the basement and out came the 275 gallon tank that was in there and we replaced it with dual 330 gallon tanks... so it is awesome, 1 delivery per year, get it when it isn't snowing/icy, so you don't have to deal with teh driveway as it is steep and they won't attempt if it is not clear, etc.
However, at 3.55 a gallon or whatever we paid last time, $2000 a pop to fill it up is a kick to the wallet!
Small update
Nothing big to report but I did get to see the new wheels and tires:
17 inch Trailready HD bead locks with 40x13.5x17 Nitto Trail Grapplers. The front suspension is completely mocked up and ready for final welds. I should have some more updates in the next month or so. :cheers:
getting closer...
The last few months have been really crazy but I'm hoping to get rolling on the Scrambler soon. The front coilover suspension is complete with the exception of some paint and final assembly/tuning.
Here is a sneak peek:
I'll be heading out to the shop tomorrow to check it out and get some more detailed pictures.
I've picked up some new toys in the last few months that have slowed the Scrambler progress:
500 HP V10 with an SMG single clutch transmission, needless to say it's very fun to drive! Just not in the snow :rotfl:
I also had to replace my daily driver so I decided to go back to driving a jeep wrangler:
It's a 2012 Rubicon with a lot of nice interior features since it's my daily driver. The new 3.6L V6 engine Chrysler put in the latest models is a big step up over the 3.8L and having a 5spd auto is nicer than the 4spd. I had a 2008 wrangler a few years ago but did have 35 inch tires on it most of the time I owned it.
I like the SMG, it's a good hybrid of an auto and manual and it has paddle shifters on the steering wheel. Although I wish I could've afforded a newer M6 since they added dual clutches.
Here are a few pictures of the front suspension:
And a picture of what it will roughly look like when the tires are mounted:
The Acme hard top is not mine but it looks pretty nice on there so I may have to hunt one down. The rear axle was moved backward by the PO so we will have to relocate it to the stock position to avoid the gas tank hitting the 14 bolt housing. I also want to minimize any trimming I need to do on the wheel wells.
I was thinking about roll cages and was wondering if anyone has done one that supports a full hardtop and half hardtop? It seems like there might be someway to have a removable section of the roll cage without sacrificing too much safety.
Work on the Scrambler has been slow lately but I did pick up a PSC hydro-assist kit for a great price. The ram is only a 6 incher so I will need to get a bigger one.
I'm going to stop by the shop next week to drop off some parts so I'll get some pictures of the progress. The half doors are mounted (thanks again Randy), master cylinder with hydroboost unit, radiator and hoses, and brake/fuel lines. The rear springs we ordered from Rubicon Express have been back ordered but should be coming in soon. I'm also hoping we can modify the stock AMC air filter unit to fit the throttle body. And the last big expense will be the custom driveshaft - we might need to do a two-piece for the front to clear the 727's solenoid and pan.
Progress has been depressingly slow but we're chipping away at it. Got the PSC steering box mounted and lines measured and cut including the hydroboost. The new 8 inch PSC ram is in and waiting for install.
Also got the SOA leaf springs installed and cheapo shocks (mounted after picture was taken)
I just want something cheap on the rear to run with while I save up for the coilovers. The front suspension is welded up and the rear pinion angle is set. The rear driveshaft arrived from Tom Woods and it is a beast. We're working on fitting the exhaust and figuring out the front driveshaft but there isn't much room between the control arms. If anybody has any pics of a similar setup with the 727 I'd be interested in seeing them.
I also had some problems this spring with my challenger's alignment so I rebuilt the entire front end: new poly bushings everywhere, new bilstein tuned shocks, bigger torsion bars, bigger tie rod ends, sway bar, adjustable strut rods, bigger rotors, new wheel bearings, new ball joints, and new idler arm. Basically everything except brake calipers and pads! I've also got new leaf springs for the rear axle and a new sway bar. Partly preparation for the added weight of the big block and just tired of 40 year old parts.
If I get the scrambler finished this fall, I will start on the 440 build soon after. Fingers crossed!
