Brake Light Switch - replacement
Wayne
Cape Coral
FL
I believe that that the plastic switch that touches the brake pedal is called the brake switch???
I think mine might be shot since I do not have any brake lights (Put in new Bulbs - and they brakes were working the other day)
Is there an easy way to swap it out or do I have the take the dash off to get to it?
Thanks
Prepare to contort and cuss.
I've replaced mine a couple times by laying in the floor on my back and hoping like hell that I didn't blow a disc in my spine or crack a vertebrae.
One of the worst jobs on the Scrambler IMHO.
It can be done without removing the dash.
This guy changed his brake switch out last week...
I'll tell you this much, if that switch ever goes bad again... Ok, WHEN that switch goes bad again, I'm putting a hydraulic pressure switch up at the master cylinder. I don't need to pay down my healthcare deductible just to change a daggone switch... My back hurts just thinking about it.
Oh know - Im going to look like a Pretzel by lunch time...
Yep thats what I did...because the last time I replaced one I was upside down with my legs hanging out the window, half on the drivers seat and the rest of me smashed up into the underdash ..I was already to replace the switch when i relized I forgot the swich on the hood... lots of cursing going on...
Sent from my SPH-L900
If you pull out the driver's seat assembly (4 bolts)/ passenger seat assembly (4 bolts) and the center console (if you have one), it is not "as bad":thumbsup:
You can then lay flat on your back (relatively speaking) with your legs toward the passenger side and wont be too cramped up.
I had to install a "dual switch" on my tan Scrambler (brake light/torque converter lock up), and get it adjusted right. If you think adjusting just for the brake lights is a PIA, pray you don't need to put in a dual switch:rotfl: Anyway, I knew I was going to be there for awhile, so I pulled the seats/console, and it was not that bad:twocents: If you leave the driver side seat in, I could see some major "comfort" issues:crazy:
This is an ex-Scrambler owner's daughter changing one on her XJ project. Not a Scrambler, but the position is about right :rotfl:
forum
And if you have AC, it's worse. I know. I ended up dropping AC down, loosening column, and loosening dash completely and resting it back onto column, then finally got to it. Just sayin.....
I have heard that if you have A/C it is worse.
And as SpankJRS said pulling the seat out is the way to go.
I pulled the seat out early this AM laid the dogs bed in there for me to lay on and the switch was out and replace within minutes. 3.jpeg2.jpeg1.JPGTotal time was about 30 minutes.
