Highway speeds/performance.
Lookuphere1
Oklahoma City
Ok
I'm considering purchasing an 85 Laredo scrambler with a 4 speed manual tranny, 31's for tires.
What will be the reasonable/comfortable highway speed for this vehicle? Thank you.
You should be able to cruise at 65-75 if it's stock, as Manhattan said, and in good shape.
Lifts and bigger tires could make it unwieldy at higher speeds, but I can cruise all day long in any of my CJ's at 70, and they're all running 31's.
3.31 gears should be pretty good with 31" tires. Highway performance should be fine (just bear in mind a CJ is not a sports car).
The 5 speed would be happier.... I cruise comfortably in my Laredo with the 5 speed and Weber at 70-75, running 31s and I think a 3.31 gearset.
As a side note I remember listening to Prairie Home Companion one day while driving back from up north and they were dueling jokes over "Your mother is so fat....." and the best was "Your momma's so fat when she hauls arse it takes her two trips...." Not sure why I thought of this when talking about Jeeps and top speed..... somewhat applicable though...
I should amend mine a little - 31, 2.73s, T5, 258 and I'd never try for more than 65 on a flat. It'd do 70+ on a hill with a tail wind, but you may do better with your set up.
Mine is an 82. When I found it, it was totally stock with 32's on it. Not sure of the gearing. I drove it my from Birmingham AL to St Louis MO. I have a warning ticket as proof that it did 75 in a 55. Sheriff didn't give me a ticket because "you don't see these anymore on the road". But I was doing every bit of 75-85 on interstate. Passing cars and getting Jeep waves.
Just got a tach in my Scram, and (not figured out the gearing yet) but has 258/t-5 with 33s and I cruise to work juuuuussst pee-chee at 70-75 and I checked my speedo the other day with a GPS, dead-on from 5-75 mph
258, mopar fuel inection, NP435 4 speed, 4.56 gears, 35s, run 70 at 2800 rpm all day.
It's all about tire size and gearing. The 258 is not going to handle hills well if you have 2.72 with anything bigger than 29's. 3.31's work well with 31's. Also the condition of the steering components and suspension are going to play a big factor in how fast you feel safe. Not to mention brakes!!
35's, 430 gears, Hemi with 545RFE, 90 to 130 highwa...oh, you were talking stock. Sorry.
4.2L Block, 7120 4.0L head, MPFI, Electric fans, 4.11 gears, T-4, 32 X 11.5 X 15's, Chrome wagon wheels, Full roll cage, no top, hard doors, 4" lift, Temp 23 deg. F, GPS = 92 mph
I have a 4.0, 2.73's, T-5 and 31's. 5th gear is useless. Will run 65-70 all day long. Commuted 40 miles each way for 20 months in it with 80% of those miles on the interstate. No real issues. Get about 17-19mpg. And that is on I-75 in the hills of east TN.
My best setup is an 86 with 4.2, 3.31s, t-5, 32s, Howell FI, DUI, and borla header and no cat. I can pull hills in 5th gear at 70 or punch it in 4th. I couldn't do that before the performance upgrades but agree with the masses here 3.31s or better.
