Highway speeds/performance.
My Red Scrambler is running:
4.2 with Mopar MPI/stock head and exhaust (no cat)
T5 (blew up three of them, currently putting in an AX15)
4.10's
33x12.50 BFG Mud Terrains
I have drove this thing to Moab, Michigan, Kentucky, Misssouri, and all over the south east. I can cruise at 75-80 all day long, 16-18 mpg, depending on speed/grades. It will get better mpg if you drive slower:twocents:
On most grades, it will hold 5th gear. On the steeper ones I will drop it into 4th once the RPM drops to 2,000. My engines "sweet spot" is 2,400-2,600 RPM, runs all day long just fine:twocents:
This Scrambler has been completely rebuilt, so all the steering/suspension is new. It drives/handles great, no problems, one hand on the wheel:thumbsup:
I am running the RE 4.5"lift. It rides nice and soft. Maybe a bit too soft for aggressive cornering, but the softness is worth the slight trade off.
My Tan Scrambler is running:
1991 350 TBI (out of a caprice classic)
700R4
4.10;s
33" mud tires
I have drove it several times for "medium length" trips on the highway, anywhere from 1-5 hours. I do not have a tach in it yet, but I believe it is turning less RPM's then my Red Scrambler. It will cruise at 80 mph all day long, but at 80 it only gets 14 mpg, but its fun:thumbsup: Slight hills/grades are no problems. I haven't drove it through Colorado, yet, but I am sure it would come out of OD on some of those hills:rolleyes:
It has an older 4" Superlift on it, the more I drive it, the better it gets. It is much firmer then the RE lift, but at high speeds it feels more stable. The stock steering shaft has a hair/tiny bit of play, but it is also a "one hand on the wheel" rig:thumbsup:
My Green Scrambler is running:
stock 4.2 with computer controlled Carter Carb with most of the feedback stuff working
T5
3.31 gears
30" Bridgestone all terrain/street tires (Dueler HT IIRC)
Not sure of the RPM, no tach. It seems happiest at 65 mph. It will hold slight grades in 5th, surprisingly, but long steep grades require a downshift. I drove it from Biloxi, MS, to Mobile, AL, and got 21 mpg at 65 mph. It will run faster then 65, but it just doesn't seem as "happy", if that makes sense:shrug:
This Scrambler is mostly stock, with 125,000+ miles on it. I recently installed 1" Superlift springs, new shocks and bushings. It rides a bit firmer then before, but much better then hitting the bump stops:rotfl: It handles the best, mainly because it is the lowest of my three, and it has street tires:twocents: I need to start taking this one on cross country trips:thumbsup:
Brick? More like barn.
Hmmm...
