Cool scrambler trailer..
deforg
Erie
ks
The guy wants 2k for it.. wow.. but it's something I really want to have for hauling my tools in.
Sent from my VS980 4G
It is nice. But when I look at it I thing about a good tub that could have been.
the whole front half was hit hard in a head on. The bed is perfect though. The owner said he let a friend drive his scrambler and it came back on a flat bed. Ouch! What do you guys think about 2k? Is it worth it?
I'm glad to hear about the wreck (in a sad way). If he did the frame correct, and you add all the parts (axle, wheels, tires etc), it might be. You have to like the concept for it to be worth it. Is it legal to be on highways and can you get insurance. My 7500 lb trailer probably set me back $2,500. a couple years ago. From a cost view it may not, buy if you wanted to build it you would spend around that amount.
Good point.. im not sure how kansas would view a homemade trailer like this. I believe its anything under 2000 gvw than no tags are needed. The grey area in that is without a factory plate with all that info creates a problem of proving its under 2k gvw.
For 2K you could buy a new trailer with a larger cargo area. But for pulling behind a scrambler, this would definitely look cool. If this trailer has enough space for what you want, then it is perfect for you and you are paying for the uniqueness and the cool factor. Just don't put more weight behind the wheels or it may want to sway from side to side at faster speeds.
Seems like a bit much but its hard to place value on "the cool factor". You can get utilitiy trailers to do similar task for a quarter of the price. If he painted it to match your scrambler then that would be something. I assume he is using the jeep taillights. If you add fender flares to your new one, throw them on here and good to go.
Very good point... id have to test pull it with some kinda load in in it. Dont want it pulling my a** around while towing it
To quote somebody (not sure who) "A thing is worth whatever someone is willing to pay for it". Personally, if I had the money laying around and wanted a trailer for my scrambler, I would probably buy it (would be great for hunting season). Definitely has some coolness to it.
I think it is really cool! It is a nice chunk of change for it but if I were needing / wanting a trailer I would go for it.
On the plus side - if you matched the axles, wheels/tires, springs, etc... it'd be a cool way to bring spare parts with you.
I agree it is cool but it will not tow well if it is not loaded correctlly. The balance on that trailer will be super critical to prevent sway. Be sure to put all the heavy stuff in front of the axle.
Where is this guy? He has other cool stuff laying around, might be worth a trip over to see the other stuff.
check out dinoot trailer. several "Jeep" based trailers you can build. I havd seen the protoypes in person, very nice. designed by Jeff Scherb who is a member of this forum. You could have a brand new trailer for under $2000, that you can say you built yourself.
a year or two ago there was another IMO nicer CJ-8 trailer for sale on this forum, try searching for it for comparision.
Yes Barry it was a medium blue one right with wood rails and much longer than this one. A forum member here bought it. We saw it I think at the PA show 2006 Ish. I have pics on my computer of it ill dig up.
Cool, I'd love to see a photo of it. I love the concept but 2k is just to much for an unfinished trailer. (Paint, body mounts , spring bushings, tool box upfront, spare tire bracket, custom luggage style rack)
It's cool but for ~$800 or so you could find a nice M416 1/4 ton Army trailer. For what it's worth I have less than $2500 in my little trailer. Either way it's your money, do what makes YOU happy!
Good luck!
When I lived in Olathe I had a Toyota pickup box trailer. I n the 17 years I was there no one ever stopped me to see if it was over the weight requirement for plates. I also had a m416, again no one cared. On the box trailer I had the spare and a small tool box on the tongue to help with the balance/whip issue. Worked great.
