Seat belts. GR8 tops
Lookuphere1
Oklahoma City
Ok
I have the new gr8 top to go on my 83 scrambler. Does anybody know how where to mount the seat belts? No instructions and the gr8 top offices are closed today.
The seat belt mount to the rollbar. They should go through a hole in the top
Dain
Half cab.
There are no holes in the cab. Guess I'll get to drill holes. Seems like that should have been predesigned considering the cost of the hard top.
Does the cab bolt to the roll bar along with the seat belt and related bolt?
On my stock top, the holes are big enough that the bushings just fit through the holes. And I believe they are designed to expand and fill the hole as the bushing is squished when the bolt for the seat belt is tightened. The bushings are not sandwiching the fiberglass of the top.
If there are no markings, good luck getting the holes in the right places.
I would consider calling Gr8Tops and asking if they have a template or the measurements for drilling the holes.
Dain
Not all Scramblers use 3-point belts, hence why they don't pre-drill holes.
Have you installed the top yet? How does the latch at the front work? pics would be great, the instructions leave a lot to be desired. thanks
Drill holes through the flat spot on the inside front edge of the top to attach the latches. Drill slowly. You will drill through fiberglass, then a layer of metal, then fiberglass again then another layer of medal. Don't drill any further or it will go all the way through. The center latch hooks through the center footman loop on the top center of the windshield frame. Remove the sun visors and attach the latch receivers using the outer holes for the sun visors. The sun visors screw back on top of the latch receivers.
I'm getting some wind noise and air leakage from the top outside corners between the windshield frame and top. Let me know if you figure out the proper way to seal that up.
I just ordered a GR8 Half Cab. Pictures of yours would be nice to help me see what I am getting and how your installation went.
