100 day summer rebuild
Day 4:
I wanted to get the body of to day but i spent well over half the day getting the bolts out from the roll bar base!!! i got the electrical sorted out and all pulled out all long with the dash. The brake boost and peddles came apart easy, but the steering column was a bear! The body mounts came off ok... i only broke one of the bolts and the others came out rather easy. Tomorrow the body show come off with out a hitch.
The wasn't a lot of visible progress today except the roll bar and dash
Roll bar out alone is progress, took me most of the day to get all the bolts out, but once they are out, it is a great feeling, the rest is all downhill!
I feel your pain even though I only had to fight with two of mine, and I had to cut and hammer mine out with a chisel. Good progress.
I actually had to do the hammer/chisel technique on 2 of the most stubborn AMC 20 torx bolts (bottom ones) on Sunday.
Heat no worky... as the torx portion was mostly stripped out.
Hammer, no worky.
Heat it up and a chisel/hammer to get it started and vice grips to do the rest.
It had to be RED HOT though to work, the little gas thing I had tried first didn't get it hot enough.
Subscribed, good luck with the build!
In your work to get everything apart, I hope you're labeling the crap out of everything, keeping bolts in bags/boxes with labels, labeling every wire/connector, etc. It always seems to make sense when you're taking things apart, but when it comes time to put them back together, it's a whole different ballgame and can cost you days.
Man DOES have a point..!!! LABEL EVERYTHING.. If they are rusty, toss all but one as a reference for a trip to the local ace hardware boltroom..!!
day 5:
The body it off!!! I'm going down to nationals for rowing in Alabama until sunday then going to Ohio for my cousins wedding. So my progress will be at a stand still until then... I'm going to order some parts but I haven't divided what all i want or need. I plan on making a post every day to keep up with things. I know that I'm what a 2" lift and a wide axle. I need new windshield hinges and a lot of new bolts and a hand full of other parts. I would like to get 33" BFG a/t on stock rims. What paint should i get for the frame and what should i get for the body
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Nice work!!!
As to the frame paint question, how much farther down are you going (I assume all the way)?
I used POR15 on my frame. Stuff sticks to everything including rust.
As for the body, that is more complicated. I went with a base coat clear coat approach which is close to factory but may not fit into your schedule. Basically, you do all your bodywork and clean up the body for paint. Apply primer to everything and let it dry. Paint multiple applications of your paint color and let it dry. Then apply multiple layers of clear coat on top. Preparation & Painting alone took me 2 months plus. Then you have to wait for the paint to setup before you can start wet sanding and buffing the clear coat, unless you have access to professional paint booth to bake the paint for you. Maybe you should look into a single stage application paint? This is pretty much paint and clear coat all in one shot. Someone else on here maybe able to get you details on that process. With all this hard work it would be a shame to rattle can paint the body, which I personally would not recommend.
I did the POR15 method on the '76 CJ7 I did a frame off on a few years back. Turned out fantastic. This time I paid a little more and had my CJ8 frame powder coated.
I'd shop around your local powder coaters and get an estimate before you firmly decide on POR15. You may be surprised at the cost. When I added up materials for going the POR method and then thought about my time, the powder was well worth the extra money.
my 2 cents
I did por15 on the frame.... Powdercoated epoxy on the bumpers. The bumpers appear to be a much harder finish. Not sure what a pc frame would cost in Kc. I know from my work that PC cost vary greatly by location.
I rolled my silver CJ7 paint job on... there is a whole forum dedicated to rolled on paint jobs. It came out decent, but it takes a bunch of time, on the plus side, it only cost like $60 or so.
Definitely ask around for a couple quotes. I also found that the more I took, the better the deal I got. I had the frame, wheels, misc. brackets, steps, rocker guards, etc. done.
Have place near me that blasted and powder coated our last few frames for $150 each.
IMO powder coating is the only way to go. It has held up very well on our trail rigs.
Might be worth your drive down to get it done.
I would really like to have professional paint job when its done, i know of a place with a spray booth and bead blast booth for rent. I think i want to paint it my self but i still want it to look really good!
Day 6:
Looking for a 220 lincoln MIG welder. I have still not decided on a lift kit. I'm Starting to think that i want to have the option to run 35's, so i might go with a 3-3.5 inch lift with a body lift. It sound like powder coating is the best way to go, so i will see what i can find out here. I'm going to get warn lockers but i still haven't found what axles I'm going to get. As far as the power train I'm still don't know what I'm going to do. I think i want to switch out the 360 for a fuel injected 242.
LOST OF QUESTIONS TODAY
1)How do i get approve to use tapatalk?
2)Has anyone done the rubicon in a scrambler(what did they have)?
3)With a 3 lift, will i need new drive shafts?
4)What are the pros and cons to using a wider axle vs. spacers
5)Does the 4.0 bolt up to the old bell hosing ok?
Hello Elliot. :wave:
Just saw your thread. If you are going to order parts, consider 4wd.com
Talk to Woody, extension 834. He is a member here and we get a discount if you mention you are with the SOA group to him. I'll talk to him for you. If you need hinges and such, remember I am a wharehouse distributor for Ken/Trol products and get most everything for 30 to 50% off for CJ-8 .com members. I can order it and have it drop shipped to you.
Good luck and keep up the good work. What part of Ohio are you going to? May be able to pick up parts and save shipping costs. Let me know what axles you are looking for also. I have several sets. :thumbsup:
You must be a paid forum member to get Tapatalk access. There is a link at the top of the ScRamblings section.
A professional paint job could very easily eat up the majority of time you have left to finish this. Many folks on here waited more than 100 days to get theirs back from paint shops. Just a heads up for the sake of planning :shrug:
Paint underside of body, firewall and inside engine bay, hood, fenders,grill, while it is dissasembled. Paint is the lsat thing you do. As Eric stated, that could take all summer itself. :wave:
