What did you do with your Scrambler today? May 2014 version
I've got a Nordskog Digital gauge cluster with a not-quite-right fuel gauge. It reads in percentage 99 is full 00 is empty. Or should be. It doesn't come off of 99% for 60-70 miles and at 40% I've got 2 gallons left. I wanted to see exactly how much it'd used when it came off of 99% so I filled it up on the way home from work a few days ago then hit the first gas station I found when it started bouncing between 98 and 99. 3.1 gallons, good to know, but the kicker is 73.4 miles!
If my redneck math is right, that's 23.6 mpg all highway. I originally thought that maybe I was just having trouble getting fuel in, so I slowed the pump down and had fuel coming out of the neck at 3.1 gallons. I couldn't GET any more fuel in it. Either somebody is messing with me and putting fuel in the tank or my carb fiddling and driving like an adult is paying off.
Is your speedo gear right for your gearing/tires or if it's digital (never heard of that brand, so I don't know what it is or how it works) is it set up properly for the right speed/mileage?
The speedo/odometer is set for my 33s. It's accurate when compared to my gps. My commute is 22 miles one way. I filled up on the way home, drove back to work, back to home, then filled up just before I got to work today, so the 74 miles is accurate. I had been averaging 17 with a bunch of in-town stop and go, but 23+ was definitely a surprise. I just ran a can of SeaFoam through the tank and fiddled with the air screws on the front of the carb last month.
Short of someone putting fuel in it or some sort of obstruction preventing me from filling it, I'm just going to accept it and be thrilled about it!
Shoot, I can afford to drive it if it stays close to that!
I tried to post a picture of the Nordskog gauge but I get a "not a valid file" error when I try to upload from my iPhone. Not sure what's up with that..
Disregard the last post.
Not as good looking as the new Speedhut gauges y'all have picked up lately, but it's functional, and it was already in the jeep when I got it.
Ok, but our stock 08 JK on stock tires can barely manage that highway mileage. Something is off IMHO, but if it makes you drive it more and smile, I'm all for it!! :cheers:
I'm fine with that! I'm sure the next fill with be back towards normal, but I can't figure out a reason to only be able to fit 3 gallons in it. I know I didn't put more fuel in, and it filled the filler hose up to the neck. Had it only taken a quarter gallon then stopped I could see it being an obstruction, but that hose ain't gonna hold three gallons... Who knows. We did that to a buddy at the firehouse when he bought a truck. We'd add a couple gallons one tank then siphon a couple gallons the next tank. Drove him nuts for a month or so.
On a completely different note, can someone take a picture or two of the tailgate bar that slides through the bottom of the rear soft top panel? Also, any measurements would be great. I'm having trouble finding a replacement so I'm going to just make one. It's a specialty top co. full top.
Ur more than welcome to look at mine in person if you'd like.
Tim
Brought it home! Actually brought it home over a week ago but just now had a chance to write about it. Getting ready to lift the rear to measure for new drive shaft. You can see my hillbilly tub-lifting device to the left.
And this is how the rear suspension worked out:
Gave my son his first driving lesson, but he had a hard time working the pedals. Maybe I should move the seat forward.
I actual got new Bestop seat covers and installed them. He ended up in the driver's seat so I could do the passenger. The wife came out and thought it was funny.
That is awesome! You should redo this photo again in about 15 years!
I took off the transmission access plate and tranny shifter and got them painted today. When I do the rebuild on the transmission and transfer case, I'm going to switch the dana 300 to a twin stick which I also painted today. The rebuild got pushed off to next weekend due to shop availability. Here are the pics. I got rushed towards the end and didn't take some of the between pictures I wanted. It was all painted with roll bar and chassis paint.
Used my to favorite tools to clean up around the lake today, My son drove the boat and I ran the chainsaw and weedeater.
