If you can contact it, you should pad it. The thing is for most of these roll bars, they can do as much harm as good. Doesn't matter much that you were not crushed in a rollover when your brain is mush. I've been seriously toying with the idea of a front cage. My problem is that the environment is so small, that in a highway style accident, your pretty much going to hit the roll bar in some way and that's bad. In any serious environment where roll cages are a must, so are harnesses, that's why they don't hit the cage. But of course a harness in a recreational style vehicle is not exactly a perfect answer either, cause if you have a harness your body does not move in an accident. A normal shoulder belt slowly absorbs the impact and actually lets a person move quite a bit, kind of like a shock absorber. A harness doesn't move if you put it on correctly, so now I increase the risk of neck injury in a massive way and now I need a helmet and neck support. Not really going to happen in a road machine for a trip to the grocery.
The "halfway" mentality of the Jeep in these things makes the whole consideration a difficult one really.
I really have not seen many, if any at all discussions around these points and tradeoffs. It's not that its revolutionary, pretty standard fare in terms of cages across sports and the reason why harnesses are not even legal in road vehicles for the most part. It just seems to me it has not been a fad in jeeps or really through through. Best explanation I've got, or maybe I just missed the conversation. Very possible. It's really not an easy thing to come up with a simple answer and approach. If you run trails, rollover is a very real concern, but when you drive it home on the highway its a whole other issue.
So in short, if you can hit it, pad it. Better to not be able to hit it at all.
