Padded Roll Bars - why not??
atlshaun
Atlanta
GA
Why does hardly no one pad the roll bars on Scramblers. Really just curious because I rarely, if ever, see any pics of a Scrambler with padded roll bars which is unlike most other Jeeps / CJ's where it's very common if not ubiquitous.
Guess is: 1) most 8 roll bars are constantly exposed to the elements; and 2) no rear seat passengers in most 8s.
What he said. Plus the Scrambler roll bars are a larger diameter then 5's and 7's so the padding doesn't fit. The only CJ-8's that had factory padding that I know of were the export Overlanders.
Yes and yes. And 2.5" vs 3". Basically an oem pad fits without the padding. That's what my overlander had. I like looking at the rollbar so I removed it.
If you can contact it, you should pad it. The thing is for most of these roll bars, they can do as much harm as good. Doesn't matter much that you were not crushed in a rollover when your brain is mush. I've been seriously toying with the idea of a front cage. My problem is that the environment is so small, that in a highway style accident, your pretty much going to hit the roll bar in some way and that's bad. In any serious environment where roll cages are a must, so are harnesses, that's why they don't hit the cage. But of course a harness in a recreational style vehicle is not exactly a perfect answer either, cause if you have a harness your body does not move in an accident. A normal shoulder belt slowly absorbs the impact and actually lets a person move quite a bit, kind of like a shock absorber. A harness doesn't move if you put it on correctly, so now I increase the risk of neck injury in a massive way and now I need a helmet and neck support. Not really going to happen in a road machine for a trip to the grocery.
The "halfway" mentality of the Jeep in these things makes the whole consideration a difficult one really.
I really have not seen many, if any at all discussions around these points and tradeoffs. It's not that its revolutionary, pretty standard fare in terms of cages across sports and the reason why harnesses are not even legal in road vehicles for the most part. It just seems to me it has not been a fad in jeeps or really through through. Best explanation I've got, or maybe I just missed the conversation. Very possible. It's really not an easy thing to come up with a simple answer and approach. If you run trails, rollover is a very real concern, but when you drive it home on the highway its a whole other issue.
So in short, if you can hit it, pad it. Better to not be able to hit it at all.
i did , see below
Makes sense on a hardtop.
Scramblers were designed to be trucks..IMHO
I take it that is a custom job?
Looks really nice. I like it!
Why does no one pad a CJ-8 roll bar?
1. They are external and the pads will hold water, look bad/fade and speed up rust.
2. The roll bar is not in the cabin with the passengers
3. The roll bar is farther back than a CJ-7 so the chances of hitting it are less
I too have toyed w/ the idea of coming up w/ some form of padding. interested to see if anyone has any ideas of what scramble1983 did ...something that wont break the bank...
Here's an old pic of my "pad" when it was on. It also uses Velcro to attach it vs the zippers we have here. Comparing it to other overlanders we determined it to be original and does have Chrysler stamped material. You can also see it has zero "padding" to it, it's basically a vinyl cover :wave:
Yes, the interior guy did it custom with the same material I used for the seats. It took him a day.
