100 day summer rebuild
Day 40:
the windshield and doors are ready for blasting...
i when to 12 body shops tester day getting quotes of a paint job.... from as low as $400 all the was to $10000 so there are a wide range of options with different time frames... and its 50 an hr to rent a spray booth at the chop shop....
i only have $750 for paint so i think I'm going to try and paint myself
hope fully i will get all of the rest of the parts blasted on wednesday and painted soon after.
As for paint i think I'm going to used a duple color 3 stage lacquer system (primer color clear coat)
hopefully i can find a good looking and durable finish for a relatively cheep cost
I had a friend paint it at his body shop.... I was in for about $1000 for materials only....
Paint alone cost me $1,200. This was for a base coat clear coat paint job. All in all for materials (not including spray guns, etc) was upward of $2000.
#1 rule with paint-- You get what you pay for.
I dabble with PPG and DuPont and I think budget paint is fine, pick a color and use Nason (Dupont) or Shopline (ppg) and you will be fine. When you want to get fancy (fades, pearls, flakes) then the House of Color stuff is my favorite. I will tell you a nice clear coat will set you back AT LEAST $100/gallon, reshooting my tailgate alone has used nearly a pint of paint and quite a bit of clear. IMO when you start using cheaper clears it is easier to get runs and solvent pop (bubbles) and haze on the edge of the spray line, all equal more work. On the topic of cost, a budget 2K epoxy primer at $70 bucks/ quart and you will need at least a gallon.
IMO the 2 previous post are inline with the $$$ it takes to shoot a Jeep using quality products
All good info. I just did my first paint job on mine last year. I went with a single stage as I was painting over tractor paint. I'm happy with the results of the parts I didn't screw up :banghead: My biggest problem was being too aggressive about how much I could paint in a session. I'm still glad I did it though and plan on fixing it once my son goes back to college for the fall.
Just be patient and break it up to manageable sections. If you want inspiration definitely check out this thread:
https://www.cj-8.com/forum/showthread.php?33830-The-beginning-the-end-and-a-fresh-start
Awesome, but he fully admits that he make mistakes too and had to reshoot some stuff.
This is exactly accurate. I'm using Nason paint. I was shocked at what a good clear cost. Body and paint work is neither cheap nor quick if done right/well. That is why you see many well built and running Jeeps that still look rough.
Day 41:
Well… i might rattle can it…
Also had to go to the machine shop again to get the holes in the plate that bolts the U-bolts to the springs widened…
paint???
It's not my money but I'd say do it right even if it means taking longer to complete. There are lots (including me) whose projects have taken years to complete. If you are going to the trouble and expense to blast the tub put a good paint job on it.
I've redone many projects that I did "quick/easy/cheap" It's taken awhile but I've learned from my mistakes. Redoing projects always costs more in the end.
Stop and think of the time and $ you are putting into this project. Do you really want to take a chance on the paint when it will be the first thing noticed?
I stated this before and will say it again, get the body blasted and in good order and then put a good coat of primer on it. Go ahead and coat the underside with whatever you want. Then Stop. Finish the build and Drive it. You can save up $ / more time for the paint down the road and be able to paint it with the body on the frame.
I've tried painting myself numerous times and with good quality materials and equipment. I could never get it right so I farm that out. Painting is something that takes time and practice to look good. It's one thing to practice on a toy for the woods but for you primary vehicle? Not a good idea IMHO.
All good information. IMO Rule #2 of paint-- You are only trying to change the color, once you achieve that goal STOP spraying. (I tell myself this on everything I shoot)
Once it is coated evenly, if you keep spraying all you are doing is building up edges on tape lines, making runs, and causing more work for yourself. Remember, all you are doing is changing the color. This goes for rattle cans too.
Day 41:
paint???
Ill again vote for the rattle can...and white isnt a hard color to rattle can to look decent enough. No need for a show quality job anyway IMHO, your gonna jump some dunes at Sandblast right ? :wave:
agreed... both of these are a combination of a roller and a rattle can... more roller on the silver one and less on the red as I didn't have the time...
and in case you don't believe
and then I cleared it.
Agree with "just changing the color" as mentioned before.
I think there was like $100 in paint and clear...give or take... from Lowe's, can't beat it and with Rustoleum, you can touch it up easy.
x2 on Rustoleum rolled on/spray paint job. If you do the prep right, it looks more than decent. Search youtube, there are some good videos on how to do it right (and some not how to do it).
day 42:
thanks again...
it sound like the Rustoleum rattle can is the way to go!!!
im sore i will have to do some body work but i will do the best i can to get the shiny look...
that axles are all put together and i will have the wheels on there soon!!!
as far as engine and shockes, they will go on as is... assuming they don't need to be a gusted for the lift kit...
thanks for the help!!!
I'm sure that will work out fine. I went with single stage and a harbor freight hvlp sprayer powered by a Franken compressor. Any mistakes were my fault, the setup worked fine. The beauty of a single stage versus a base coat clear coat is that I can go back and fix the mistakes, more easily do spot repairs in the future, and it was much cheaper.
day 43:
so today was event full...
my father pulled out a mill/lathe from "storage" that i had no idea even existed!!!
could have saved some money on the axle hangers
tried out a bunch different paints today and found a combination that i think looks good, but ill have to check in the morning....
The guy who does the blasting also rents out a spray booth, with the money i save with rattle cans it maybe practical to rent???
i painted the the wheels as fallows:
2 coats of Rust-Oleum Professianal primer fast drying
4 coats of Rust-Oleum Professianal High performance enamel fast drying
4 coats of Rust-Oleum Crystal clear Enamal
hopefully the wheels turn out well and i will do the body with the same process
i also painted the shocks today and will mount the tires tomorrow...
the plan for tomorrow is to have a rolling chase by the end of the day!!!
forum
[/URL][/IMG]
forum
[/URL][/IMG]
forum
[/URL][/IMG]
forum
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Agreed, wheels turned out nice. :thumbsup:
You may need to give your dad a lunch break before he eats all your parts though. :wave:
