100 day summer rebuild
Day 28:
I spent the day with the rander and a wire brush...
i think i am going to paint the axles, drive shaft and engen block red...
still looking for a full hardtop that needs a lot work
what is the story about rear disk brakes
I'll offer some advice from the time I've spent on mine and watching people on here. I'm not being critical I'm just trying to help and I'm posting rather than sending a PM to help others who may be reading along and planning their own build.
You need to take one day and make a plan of what you're going to do this summer and stick to it. If you're distracted by trying to figure all this out piecemeal you'll either get frustrated fast or spend time and money needlessly.
You are now close to a third of the way through the time you have to get this done and you're finishing the disassembly. That's great but it's much slower going together than coming apart and you have some major time sucks (paint being the largest) left.
IMHO, unless you're willing for this to extend well past the planned time, you should be putting it together essentially how it came apart. The lift is fine with larger tires and basic upgrades that are a part-for-part swap, but when you ask about massive changes like SOA, a 4.0 swap and fuel injecting a 360, I can't help but offer this advice.
Ultimately I want you to enjoy the build, spend time and money wisely and end up where you want. So I'm not trying to be harsh, just trying to help that come to pass.
My :twocents: and good luck with whatever you choose to do. Enjoying the thread! :wave:
I completely agrees with what BW is saying. I know from experience. I had planned on my frame off rebuild to take about 6 months (about double your time frame) and here I am going on 3 years and not done yet! If you stick to taking it apart, fixing rust, and putting it back together you're still going to be pushing your 100 day time frame. You can always upgrade stuff later. Your time line doesn't allow for it now.
Yep your young and its your Jeep do what you want with it but i would suggest that with your time scale get it back on the road and then modify at your leisure.
Which has the added bonus in that you will still be able to drive the Scrambler as well, which i cant! (4 years and 4 months in to my rebuild:o)
Day 29:
Well...obviously I'm in over my head, but I’m not worried. I ask these ridiculous questions because I don't know that they are ridiculous!!!! I don't have one goal in mind yet but these kinds of questions are necessary to help me understand what is reasonable and what is impractical.
I'm not going to be the idiot who eats my words later.... So I will make a written 66-day spreadsheet with every job and modification planned and schedule for the time I have.
I’m taking tomorrow off, in order to determine what kind of jeep I really want...
PLEASE help me plan this build…
Big questions:
What is the general consensus about bed-liner/rinoline on the interior?
What is required for an AMC 360 fuel injection conversions?
Do I need to plan for any machine shop work?
Are there substantial benefits to rear disc brakes?
Besides paint, what are the biggest time consumers?
Should I try and rebuild the tranfercase and transmission (just to learn)?
Where can I find a full hardtop for under 1000
Which 1” body lift should I get?
With 4” of lift do I need new drive shafts?
How do I get the crap out from inside my frame?
IMO: Bed liner is undercoating and belongs UNDER the vehicle. Anytime I see undercoating inside a vehicle it tells me there's something to hide..RUST.. plus it looks bad. But itd oes have an upside in that you can prep and spray the interior and underside in less time and with less prep.
There are kits available which typically coast well over $1k. There's an ECU, electronic sensors required to meter air, throttle postion, O2 emissions, and the associated wiring harness to connect the mess. Higher PSI fuel pump and associated fuel lines and connections. In the end the fuel economy will be negligible but fuel inj does have the easier cold start benefit. For now stick a carb on it and go. Fuel Inject later when you have more time and money... and knowledge.
Only if you open the motor up. If the motor runs don't split it open open now. Change the valve cover seals, oil pan seal if leaking, front and rear main seals. Exhaust manifold seals and any other easy to change gasket/seal while it's staring at you on the stand.
Absolutely, but keep in mind the whole world rode around on drum brakes, then disc and drum, and still does on many new cars, successfully for many years. Discs will stop better, period, but once again you will be incurring about an additional $600-800 in parts not including the time & labor to get the brackets welded to the rear axle tubesin order to mount the calipers.
Everything you're doing is time consuming. It just depends to what degree you take each portion of the build. Work with what you have that still works. Put the vehicle together and get it functioning. Get the bugs out. Fit and finish can be worked out after all the mechanicals are sound.
NO! That DANA300 transfer case will only need a fluid change and will survive longer than the last cockroach. Rebuilding a transmission requires specific knowledge, precision measuring tools, a suitable overhaul bench with fixtures etc... to do it right, and could include several hundred dollars in parts only to find out you should have left it alone because it was fine. Once again this is something that can be tackled later if it is even required or worth it.
Between here and Craigslist I've seen several over the past few months.
IMO, stay with a factory height body bushing and get a 4" spring lift. Include a drop pitman arm and a tie rod flip kit and call it done. You can easily run those 33's with no clearance isues for most of what you will drive through.
NO
With a hose and lots of patients. Lay the frame on the ground and wash through the frame rail openings while rotating the frame and elevating one end at a time in no particular order.
Now get r done... Good Luck... and there r no stupid questions except the one you didn't ask when you thought about it, but went ahead anyway.
All good advice. I do agree everything takes time. Priorities: preserve chassis (clean ,de-rust and preservative coating), clean, prime and paint undercarriage with rust inhibitive coating including inside of support channels, instal stainless brake lines and fuel lines along with working emergency brake cables and hardware, install heavy duty steering box mount and brace due to 33s and towing, check steering components and replace/rebuild as needed (u-joints, bushings, bearings), install axles and suspension, Install engine, trans/transfer, drive shafts (replace all worn u=joints) along with all associated brake parts. Prep and paint firewall and underside of hood, inside of grill along with inner fenders. I usually prep and paint the interior of cab at this time while all is stripped from wiring & plumbing. Installing the tub is next, assemble e-brake assembly,heater assembly (recommend rebuilding assembly with new heater core and Blazer heater fan motor, defrost hose, ect) peddle assembly, dash, steering shafts and wiring. Get as much of the engine bay completed before installing fenders and hood. :thumbsup: This should leave you a couple of weeks to complete interior,bleed brakes and put a coat of primer on it. You will need to be very diligent working on this project to get it completed. Every day you don't wok on it now, may turn in to a month or so you are at school without it next fall. The days will melt away on you before you realize it. Steady, long days are required. We are here for you. work hard now to enjoy your Scrambler sooner than later. As you know you are taking on a major project but I have confidence you can "Get'er Done" on time with a lot of hard work and long hours. You are building memories that will stay with you the rest of your life. Your off to a good start. :wave:
As far as bed liner, I use only comical spray in on the ones that are being "Used" as trucks to protect the floor from scratches. I always pay the extra for the UV blocker to be added. MY "Fake 8" has been in there for at least 6 years and still looks like new. :thumbsup: :wave:
Day 30:
i have done a substantial amount of thinking…
I know may priorities are all out of whack but this is the quick run down
1) The body,fenders, hood, and the windshield (repaired and painted the best I can
2) The appearance, is most important (crisp and clean)
3) The drive train will go in as is… if theres time left in the end i will try and paint the engine
4) full hardtop
Other then that its full speed ahead putting it back together exactly the way it came apart
Good new plan. You can do the fuel injection, rear disc and other no essential upgrades later down the road. Focus like you said on cleaning and painting. I don't even think I would do the locker in rear right now.
Day 31:
Spent fathers day sailing around on the lake with my dad!!!
i was up till 5 this morning, grinding, sanding, and degreasing the axles. finished painting them today.
My mom is pressuring my dad to make sure my jeep is "safe", but how necessary are bucket seats and 4 or 5 point harnesses Im planing on doing some 4 wheeling but nothing too extreme….?
forum
[/URL][/IMG]
Safe is a roll bar and shoulder belts. Remind her what a Smart Car looks like after a 25mph collision and that you will be wrapped in good old American Steel.
This project is awesome. Good luck! Can't wait to see what's next
Day 32:
ordered more parts and started putting the axles back together…
the frame will not be dun until wednesday night so i am getting every thing else ready…
I'm going to paint it white...
nice work im subscribed. i read most of your thread your on the right track. you can always upgrade later on when more funds / time are avail. look through my thread, https://www.cj-8.com/forum/showthread.php?27789-Scrambler-on-a-budget i too have a budget build. i dont have any cash to waste so i re-used all that i could. daystar body lift is what i used and liked it. [ i had to ditch the stock fan shroud but i planned on the contour fan mod anyway ] the black diamond 3" lift is perfect for me and with the 1" boomers i run 35" tires.
i say PAINT IT! at whatever cost you can afford, its all apart now so any color will look factory because you can get paint everywhere and might be cheaper because your doing the assembly.
safety:
put 3 point belts in
use camber correcting wedges on the ft axles
sport cage is a good decision [ rock hard ]
good luck
