Who's got two thumbs and a winch?
I picked this one up today for $100. Thanks to a forum member who gave me the heads up.
No clue if it works or not.
Me personally? At $125, I'd snap it up in a heartbeat. Solenoids are easy
This is what I am using to rebuild mine:
http://www.pirate4x4.com/tech/billavista/8274/
and using this for reference:
http://forum.ih8mud.com/threads/my-warn-8274-rebuild-part-1.197470/
I bought mine for $200 not knowing what I was getting into because the next cheapest in my area was $400.
X2! Easily worth $125! There are a ton of rebuild write-ups for these winches and even after your cost of rebuilding you will have less in it then a new one.
Apparently he's already replaced the motor with a Chinese one. It looks like something's missing here. I'm not an 8274 guru. He said he replaced the solenoids with bigger ones and the case won't close now. He's asking $125. What do you think? Pass?
I think I would have bought it yesterday. You could sell a top gear housing without the freespool for what he's asking. BUY IT.
Score. I have an XD8000i on my green CJ7. When I put the 8274 on my Tan '7 and used it a couple of times, I quickly realized that I wanted more 8274's. They're that fast and strong. The XD pulls fine, and a buddy of mine is going to buy it for his YJ, but it's no 8274.
I picked up two more 8274's for $400 (one was missing solenoid pack) and just about have them ready to put on the Scrambler and the green CJ7
I've heard that they're the cat's meow. Hopefully I can retrofit my Ramsey mounting plate to accept the Warn. Hopefully this one will be worth rebuilding. It does have the control with it still. I gather that this one is an older style? Is there any thing to look out for on them? I read somewhere that the solenoids changed and that the older ones use starter solenoids?
With the solenoids... The PO said that he replaced the originals with bigger ones then found that the control box cover wouldn't fit with the bigger solenoids. Has anyone switched to an electrical contactor? Ramsey is switching to them and I believe the Warn uses one on their 10 or 12,000lb winch. If they fail they fail in the open position so they just stop moving the line as opposed to a solenoid being able to fail in the closed position and having a situation where you can't stop the line unless you disconnect the power to the winch.
With the regular style solenoid, what is a good replacement? I think I would need the old style, but I'm not sure. I've heard "ford starter solenoid, golf cart solenoid, etc".
Also, if he replaced the solenoid with older Ford starter solenoids, they're not rated for continuous duty cycle like the winch solenoids. They can fuse open and create a dangerous situation where you winch is still pulling when you don't want it to. If they're not winch solenoids, I wouldn't recommend using them.
With the Summit and EV products, do you need two or just one? The Summit is $110 where the EV is $55.
Just one.
It replaces all 4 solenoids.
Someone much smarter than me can probably explain it better, but the original solenoid set up was single pull (pole), single throw. So you needed two solenoids for out and two solenoids for in. This setup is double pull (pole), double throw. and does all of that in a single box which will easily fit under the Warn cover.
I got some continous duty solenoids from DB Electric and found they wouldn't fit under the 8274 solenoid cover. I ended up getting a used solenoid pack off of ebay, but for my "extra" 8274 I think I'll try the superwinch contactor. That $55 job is an Albright "equivalent" made in China. Anyone have any personal experience with that particular one?
I have a half dozen ATV's with winches, and they use contactors. Seem to work fine.
So, I talked to the WARN rep this morning and he is sending me a new cam gear! Hopefully, I can finish up the "Honey Do" list piled up, get the cases painted and begin reassembly.
All of my interactions so far with Warn have been absolutely outstanding. They have backed their product 100%. I am impressed as poor customer service is a serious pet peeve of mine.
That's great to hear. Ramsey wasn't too helpful with my last winch. When I took the motor apart it was missing one of the permanent magnets in the case. You could see where it was glued in at the factory, but it had to have fallen out before it was assembled. There's no way a magnet that big could've broken and left the case. There would've been fragments stuck to every metal part of the case. It made sense that it seemed underpowered.
So today I picked up $33 is stainless steel hardware, grease fittings and straps so I can start putting this thing back together. The only thing the hardware store didn't have was 7/16x14 1 1/2" grade 8 bolts for actually mounting the winch to the plate. They only had one so I elected to wait until I can pick up all 4.
I kind of looked like a grease monkey crack addict with my little ziplock bags of bolts on their counter and going back and forth with two bags at a time to find what I was looking for. It was probably funny as hell for the guys that worked there.
Also tested my solenoids and two of the four are still good. Funny part is, it's the two I didn't break studs off of, so either I broke the actual solenoid part when I snapped the studs or they were already broke and I just got lucky. Either way, two less things to worry about. If I go the Contactor route, then I'll probably throw these up on here for someone for spares.
