Cj7 (d300) panic...!!!!!
K9rockydog
Glendale
Az
ok.. so.. I sold the scram.. :banghead: :angry: but now.. I have to get the CJ7 up to snuff, and ready to drive and/or sell.. (had a frame-off before I got it, but the p/o [he got it from the guy wot dun the frame-off] abused it w/o doing any TLC..)
anyway.. so decided to throw the carpet that I got for the scram.. into the CJ.. and when I was doing so, I discovered that the t-case.. (D300 w/a twin stick) was in 4high on the front side !!! the WHOLE TIME I HAVE OWNED IT..!!!
the WAY I found this was I moved the sticks around.. looking for neutral.. (WHY I didnt do this before.. couldnt tell ya.)
and then noticed when I put any force either way.. it rolled FREELY..!! :eek: :eek: :confused: :huh: :banghead:
so I engaged the t-case again.. (mind you, the engine is off, th400 is in park, and there is no actual e-brake, as it has a 4-wheel disc conversion..)
and it didnt move again..
WHY DOES IT MOVE, IF TRANNY IS IN PARK..???????
If the transfer case is in neutral and there's no parking brake....it will roll, there's nothing to hold it in place. With the hubs unlocked, being in 4H didn't really do any damage, just a little extra wear on some front driveline parts.
right.. except it AINT in neutral.. tranny is in PARK..!! which is what has me geeked..!!
The transmission doesn't matter, no matter what gear it's in, if the transfer case is in neutral...it will still roll.
Listen to John. Think about it. Draw yourself a little diagram/flow chart. You'll get it and say "D'oh!"
Fyi, some CJ peoples, who trust their e-brakes, will actually pop the x-case into N when they park it out and about, as a freebie anti-theft move. Figuring some kid comes to hotwire it, tries to drive away, can't go, gets all confused, and bails out because they can't get it to move. Most regular people never knew, or don't remember the tech from our CJs.
o
The transfer case is a secondary gear box that is directly between your transmission and the drive shafts. If the transfer case is in neutral then your are disconnecting the output of the transmission to the driveshafts. This is why it moves while the tranny is in park.
ok.. talked to a friend, and talking it out, I THINK I now get it.. my next question which ties into this.. (4wheel disc converted, so no e-brake). will be in another thread..
