- Stillwater
- ok
There is a fair amount of info about converting to YJ springs.
Since the YJ spring is longer, the hanger needs moved back and needs to be wider to accommodate a 2 1/2" wide spring. As i read, something doesn't make sense.
First, the hanger kits, like from MORE are bolt on. But the frame is enclosed, how do you put a nut on it? I know i can weld it, but...
Second, my hangers are 2 7/8" ID. how wide does the new one need to be? I think I may fab a new one or even modify the old ones.
Also worth mentioning is that the rear shackle hangers that are 2.5" wide work well for the front - just buy a new set, knock out the front crossmember rivet, and use that hole with the other and it's the right distance apart for the YJ front springs.
