What's in your off-road kit?
Breal
Jackson
WY
I want to build out an off-road kit and would like to put together a comprehensive list of things to carry with me on 4x4 trails. What's in your kit? Feel free to state the obvious and also if you have reccomendations of what you carry it in(duffle bag, tupperware container, etc…) that fits well in the back of the Scrambler.
Would be great to know what is "essential" and what is a "nice to have".
I'll start with a few items....30' strap with loop ends, tree saver/short strap, winch pulley, 3 or 4 shackles, spare fuses, tire plug kit, radiator stop leak, a couple of spare lug nuts, spare fluids, spark tester, small multimeter, spare u joints for driveshafts and front axles, folding shovel, TP, gloves, rags......
That'll give you a start.
Screwdrivers wrenches, pliers, etc and a bfh for persuasion...
I keep mine in a drawer i made for the bed of the scrambler
Alternatvely you can just wheel with a buddy who carries all that crap and you just carry a small cooler...
Great start. Thanks John.
Add duct tape, spray lube, bearing grease, drive shaft u-joint straps and bolts or u-bolts (whichever you have), small ratchet straps, bungee cords, assortment of basic tools, spindle nut socket, long breaker bar, hand held CB radio (for those long walks)....
If you need it to stay together: Duct tape, bailing wire, zip ties, 2-part epoxy
If you need it to come apart: sharp knife, hack saw, pry bar, BFH, pickle forks
Other useful tools/equipment: good assortment of standard and metric wrenches and sockets, screwdrivers, adjustable wrench, chanel locks, vice grips, funnel and hose (filling diffs), tire plug kit, u-joints and straps.
I have a large tool box but it weighs over 75#. I'm looking for other ways to carry it all.
Here are some thoughts.
Send some time learning what size fasteners are on you Jeep then select your wrench selection accordingly there is no since in taking an 11/16 wench if your jeep doesn't have an 11/16 fastener.
Enough oil to refill the crankcase, and t-case.
A hacksaw bade handle, one of those things that hold a blade
Needle Nose vise grips small
Standard size vise grips
Role of high quality electrical tape
Jb weld
Role of 10 gauge electrical wire
Assortment of a replacement hose clamps one of each size on your rig
Replacement fuel filter
Belts and hoses maintenance parts that you will use anyway.
The best tool to have is preventative maintenance it fails to amaze me when some breaks a ujoint on the trail and when you get it out you can see that it hasn't see grease in along time (forever).
I'll add;
Snap-ring pliers, heat-shrink butt connectors, a spare hub lock-out or drive flange.
And more specific to my build;
Spare electrical relays, 8 ft roll of high pressure fuel line, fuel pump.
Mechanics or leather gloves
I'm beginning to think this list needs to involve tool boxes along with dimensions.....
It appears that a Craftsman tool chest is in order....better yet a Bantam trailer to all the crap along with the cooler!
mosquito repellent.
bad enough to wrestle with breakdowns, anguish, and creative problem solving without the added trouble of being prey to the little devils while you're trying to get yourself out of the latest fix you got yourself into.
mosquito repellent.
Bottle opener and a roll of TP.
Not being a smart *** here, better to have and not need, than need and not have.
Nice additions! In both cases! It's those little things that we often don't think of at the time but when things can't get worse.... The mosquitoes bite and the bowels grumble..... And it gets worse....
