How much does a frame weigh?
I think that's it. If it's a late 81 the 3 holes are already there, just cut off the shorty towers. Early 81 doesn't have the 3 holes, but I can make a template off of mine and send it if you want.
I also have a set of the 81 lower spring plates if you just want to go with the existing brackets. I think the shock is shorter, however.
The current plan is to swap the towers for the longer ones. I will look to see if the holes are there or not. Thanks.
Here's a couple pics of my late 81 frame, with holes.
Randy is right, you can use the 81 shock tower with the 81 Spring plate and the shock will clear
No holes. Must be an early 1981 frame. Hmmm. I will need the template.
