- Columbia
- MO
So I'm installing an OEM 20 gallon poly fuel tank and I have two issues I'm trying to resolve.
1. I do not have a tank strap. I'm installing it into a Genright skidplate. Does anyone know where I can get a strap? Here is what it should look like:
2. The sending unit I bought is a pretty crappy reproduction from Omix-ada that I had to significantly modify to get to fit in the tank. I'm not happy about it and I'm concerned about how well/reliable it is going to work. Now I'm debating about going with a Crown brand sending unit or with the Speedhut unit. My only issue with the Speedhut unit is that I must use the Speedhut gauge with it. If I ever wanted different gauges or didn't want to spend the money on Speedhut gauges I'd have to drop the tank and swap out the unit. Also, it looks like I would have to drill the tank to mount the Speedhut unit and I'm not sure how that works exactly. Has anyone done this yet? Is Crown a good unit? Where can I get a brass float?
Thanks for any info!
