20 Gal Fuel Tank Question
Polarfire
Jeep Aficionado
Columbia
MO
So I'm installing an OEM 20 gallon poly fuel tank and I have two issues I'm trying to resolve.
1. I do not have a tank strap. I'm installing it into a Genright skidplate. Does anyone know where I can get a strap? Here is what it should look like:
2. The sending unit I bought is a pretty crappy reproduction from Omix-ada that I had to significantly modify to get to fit in the tank. I'm not happy about it and I'm concerned about how well/reliable it is going to work. Now I'm debating about going with a Crown brand sending unit or with the Speedhut unit. My only issue with the Speedhut unit is that I must use the Speedhut gauge with it. If I ever wanted different gauges or didn't want to spend the money on Speedhut gauges I'd have to drop the tank and swap out the unit. Also, it looks like I would have to drill the tank to mount the Speedhut unit and I'm not sure how that works exactly. Has anyone done this yet? Is Crown a good unit? Where can I get a brass float?
Thanks for any info!
I dropped in a Crown without any issues.
As for the strap, I cut an aftermarket 15 gallon one and shortened it.
I used a Crown sender as well. I asked on other sites, was told they are not much different. Don't know about the Speedhut
The brass float is cheaper here, and snapped right in: http://www.summitracing.com/parts/SDK-C0AZ-9202-B/
I made a new strap from thin flat-stock I bent on the edge of my bench. I bent and pop-riveted a holder loop to the top of the strap, and used single layer rubber door sweep/seal as an under-strap insulator on top of tank. Bought all that stuff at Lowe's.
I ordered a Crown sender and a tank strap from Quadratec and will be installing them this week. Just looking at the Crown sender I can already tell it is a nicer unit then the Omix-Ada one.
For the strap:
On my red Scrambler, with a OEM 20 gallon tank and a Gen-Right HD skid plate, I used a repro 15 gallon strap. We cut approximately 1" of metal out of this strap to shorten it, worked perfect. But, the repro straps don't have the handy "hose organizing extension" on the top like the OEM straps do. Not the end of the world, wont be OEM, but it will work
Same problem with OEM tank and skid plate, had to shorten a 15 gallon strap:
https://www.cj-8.com/forum/showthread...lon#post268009
For the strap:
That helps a lot, thanks! I ordered the 15 gal strap and will modify as needed. I may add a "hose organizer" loop like the OEM one. I'm suprised it was so hard to find an OEM one. I even called Collins Bros as a last resort and they didn't have any either.
Ok so the strap I ordered was long. Not a big deal, all I have to do is cut it and weld the threaded bolt on to secure it with.
This the Crown part number for it:
I took the space from the middle so I didn't have to mess with changing the bolt at all.
