replacement torx bolts
gary81cj8
pace
fl
Has anyone else used the crown replacement torx bolts? I purchased a set of zinc plated torx bolts. They look nice. However the beveled parts seem thicker. Not allowing the bolt to sit flush. I still need to paint the bolts thinking it my look worse once thats done. Should I try to purchase oem and clean them up to use. Or just move on with the new. Thanks
I'll bet plenty of people on here have lots of them that we've taken off of our Jeeps. I know I've got a bunch of them around my shop.
I'm sure Dustin/Jeeperdd has plenty more than me, but the size you need would be helpful.
Torx bolts get a bad name around here because jeeps rust so badly. Appearance wise they look better in the oem hinges recessed and flush.
Put a dab of grease on em and you'll be able to get em out for 100s of years. :eek:
Just my .02 :)
You can get similar bolts that have a "allen" head instead of a "torx" head, work much better, look similar.
How do they work much better ? :shrug: :cheers:
It's not that they work better, but it is one less tool I have to carry around in a multitude of sizes. Also, I've stripped out many more torx bolts than I have Allen bolts. The surface area contact from the bit to the bolt surface is too small on the torx and stripes easier (in my experience anyway).
They just look better too. Allen bolts remind me too much of flimsy Chinese stainless hinges and other things that are otherwise aftermarket crap. Do u really need to carry around torx bits ? Do you carry replacement windshield hinges around too ? :crazy: :wave: :)
Anyway back to the thread , I have some torx but am also roughly 5th in line .. No worries either way. :cheers:
Well, guys i have striped out and drilled out at least half of the torx in mine so I am currently on a quest for either cap screws with a tapered shoulder or a tapered washer to put under a standard cap screw.
Has anyone seen any?
Nothing else but torx will do !
I'm going to have to agree with Jersey jeeps on this one
Anything except the torx looks cheap to me and it's a huge pet peeve
Yep JCC! It's the better bolt. It just gets a bad rap cause of what it attached too!!!
Another thing if you can get proper heat on the nut that's behind any torx bolt its going to come off no matter how rusted. And sometimes that means cherry red. Now that's not practical for everybody to have an oxy acetylene torch laying around but as soon as you start messing with torx bolts on a 30 year old jeep thats been exposed to salt you're going to get frustrated real quick. Strip out the first one drill out the second and u will want to throw every torx bolt in a river. You will have nightmares drowning in a sea of torx bolts.
You can remove them with an allen wrench, no torch required:thumbsup::wave::cheers:
Either way, the rounded out torx head or stripped out allen head are esay enough to drill out. Those stripped out holes make perfect centers for drill bits to go straight through the bolt, then you can usually re-tap the threaded insert, no problem.
Torches due bad things to paint, ask me how I know:thumbsup:
I do agree, Torx look better if you are doing a true "restoration". Mine are all drivers, so wasn't too concerned. The bag of stainless steel allen headed bolts I used in place of the torx bolts on my red scrambler look/fit the same as the factory torx bolts, only difference is the 6 sided hole vs the torx hole. I bought a bag of 50 from Fastenall, used them on the hinges (door hinges/tailgate hinges/etc). It might be problematic to paint them, but I am sure you can get the same thing in regular steel. I would rather have painted bolts, but the first time you remove them, the paint gets ruined, so:shrug: I coated the threads with anti sieze, I can go out and pull them all back out with an allan wrench, no problem:thumbsup: but, being stainless, if you constantly are taking them in and out, they will start to round out. But, stainless is nice and soft, drills go through them like butter:thumbsup:
