regular guy
- Cameron
- NC
That looks awesome!
Looks great!They took a little patients but I was able to use vinyl pinline tape and get the letters done. The trick was to move the Jeep outside so I had better lighting, but I could also use the glare to help guide the tape line. They came out pretty good. I like the look.
The parking brake cable looks like it's rubbing but there's about a quarter inch once I pull the lead cable tight. I will have to put a couple bends in the fuel and brake lines where they pass around the rear shock. A few little tweaks here and there as I go.
And the over head shot
FYI - I also have dual exhaust exiting out the sides like above. The only complaint I have is when first fire it up. My Scrambler is in the middle of a 3 car garage and it spits condensation while warming up all over my other two Jeeps. I've got to where I now let it roll back some out of the garage before cranking.
I'm very pleased with the exhaust. I placed the brackets on top because I kept the system up tight and within the frame rails. I didn't originally plan to place the mounts above the standoffs but once the system was mocked up there wasn't enough clearance to mount the isolator below the standoff and weld the mounting pin to the pipes. Essentially it works the same and there's still plenty of room above the isolator to body so it's not an issue. I used ES body bushings which I believe are ~1" thick vs the oem ~3/4" so it's negligible.
I also mounted the rear most hangers above the cross member using the same idea as the fwd mounts.
I had to do rear/side/corner exits on the 5 because of the smell with the vortex affect coming back into the cab.
It sounds totally different than when it was straight out the back and it doesn't get onto any vehicles when I start it up with the condensation and best of all... NO MORE STINK!
That looks better than squaring them off behind the wheel too. I think they would look even better if you took a saws all and slant cut them back a tad.
