My De-Rustification Project
Did you get your jeep running yet
Just got home from the airport so no. I will try to get a coil tomorrow. If it works, then I will return the bad one and get a replacement to use as a spare. I don't have a week plus to wait on the return process.
Nope. I installed the new coil. Still no spark. I am open to suggestions. I do not want to keep throwing parts at this.
12v into the coil. No spark coming out. Cleaned the contacts on the cap and rotor. Not sure if that would kill it completely but did it for giggles.
There's not much it can be. All it takes is a good voltage source, pick-up coil and harness, module, coil, and the ground strap for the coil. Some people make the mistake of putting the coil button on top of the rubber insulator. Then the rotor tab intermittently touches the coil button or not at all. I'd personally start with disconnecting the tach(if you have one) and replacing the module.
The module is that angular flat part under and behind the rotor? That was new in January as well. But there is not much else it could be.
And as for the button, I put it in the cap (spring up) then put the rubber isolator down with the spring through the hole. Then put the coil on.
Thanks for the input so far. The module is only another 25 so worth a shot
Installed a complete new distributer today. Fired right up.
Hopefully a long term fix
No kidding. USAA is tired of paying for the towing and I am tired of getting towed. My wide said we ought to buy an old wrecker since we need it often. Sad.
So if all goes well, I will be taking the 81 frame to a guy about 1.5 hours away to have the new body mounts and rear cross member welded on. I have been busy lately just trying to get the old %&*#$ to run reliably. Well with the new distributor in now, I will be use it to drag a trailer with the frame down to the shop. Wish me luck. The trip is scheduled for tomorrow night. I will pick it up after I get back from vacation at the end of the month. Then it will be time to drill the holes for the front shock towers and then coat/paint the frame. Slow progress.
On the way down the temp got past normal but topped out and held steady around 200. Stopped to eat to give her a rest before heading back. Thanks for the good wishes. I would hate to crash in Jim's Chop Shop for the night.
