I have always wanted one of those tube frames...
It can still be yours and you can fulfill your dream!
Too bad you're cross country or I'd find a way to make that happen.
baby steps!
Great template[emoji106][emoji106][emoji106][emoji106]
Sent from my SM-N910P
Glad that template worked out for you. I should have made copies, but just like taking pictures, I forgot until after it was too late.
I believe there is a sleeve inside the frame for each of the three holes. Keeps the frame from crushing when the bolts are tightened. Would be easy to do, just cut tube to fit inside the frame and work them into position through the large hole. Use something like another bolt or a dowel to hold the tubes in place from the back while installing the shock tower bolts from the front.
I finally got to try out the sewer drain cleanout to clean the insides of the frame tube. It works just fine but I wish I would have bought the 1/4 inch one instead because it would fit through most of the existing frame holes. I first ran it through with air and then rain it through with it attached to my pressure washer hose. It's a little messy but it does exactly what I had hoped it would do. This could be the answer to cleaning out the frame tubes. I may even try building a paint pot so that I can pressurize the pot and attach about 15 ft of hose with the nozzle on the end and try to coat the inside of the frame tube with a good coating. When I'm completely finished with this it may be something that can be passed from one member to another. Then again the 1/4 inch one only cost about $18,00.
Painted the inside of the frame today. Next up is the outside. Any suggestions on what to use?
Mines painted with rustoleum !
Yes , but I don't exactly have to clean it very often
