My De-Rustification Project
I ended up having to make one as mine was rusted as well... not too difficult to do, it basically helps to hold the 2 lines coming off the top of the brass block as well as keeping them out of the way of the plug that goes into it.
Thanks. That is what I figured it was doing. I will see about fabbing one up.
Same here. Never bothered to make one mine will be lucky to see rain once a year.
I got to build one for the one I'm working on now, I'm going to use aluminium this time
Sounds like a good call. Any concerns with any reactions between the steel of the frame and the aluminum? I am not a chemist, so just wondering.
The steel plate lasted over 30 years so why not make another and worry about it in 30 more years, A aluminum one won't be nearly as strong as the steel plate either. I'm not a chemist either but I did retire after being a sheet metal worker for 35 years. Electrolysis between aluminum and steel is way over stated. If you think it is going to be a problem just spray a couple coats of paint between the two.
I've been following your thread and just mounted mine back up with original bolts the other day.
Put a coat of paint on the springs and the rear axle tonight.
Decided to attach the rear springs to the rear axle (obviousky). Too bad the shackles I ordered did not arrive as planned today.
And lined up.
By the way, is there an easy way to get the main eye bushings in the leafs? Man they just don't want to go in. I think the last time I did it, I used a mallet and did it before bolted to the axle and had them in the ground on their side. Too late now.
I lubed mine first with grease then I used a large C-clamp the suck them in.
A lot of new paint in the eyes isn't helping either.
I will hopefully have time to try the c clamps tonight. Got some grade 8 bolts for the main eye locations of the springs this morning on the way in to work. Hopefully the shackles arrive today. Then I can get the whole rear axle assembly on the frame.
As ai keep saying, slow and steady. Ugh.
So I actually got something accomplished today. It took a LOT longer than I had planned. But why would I expect anything else from this project.
Anyway, I got all of the bushings in (I will need to by a larger c clamp (or something) to squeeze the main eye bushings in a bit further on the front leaves. But I got the rear leaves all done. So now I have an axle hanging properly. Woot.
And proof that it is not resting on the ground.
And that deserves a beer before all of the little kids start hounding me for candy.
This guy just looks like he is proud of my accomplishments. ;)
You can hear him chanting "Dain,Dain,Dain,knows no springs bushing pain!"
