Impact wrench
wm69
Silver Member
God's Country
AR
Wife got me a compressor for our anniversary, so now I need a decent impact.
I'd like to keep it as cheap as possible, but know you get what you pay for with tools. I'm a hobbyist so don't need a thousand ft lbs, but need to break loose the occasional stubborn bolt.
Looking at this setup. Is ingersoll rand gtg or should I be looking elsewhere?
Ingersoll Rand 2317G Edge Series Air Impactool and Ratchet Kit, Black https://www.amazon.com/dp/B004CY1DSS/ref=cm_sw_r_cp_awd_z4Ewwb7QXJPPQ
Reviews paint it in a good light.
Localism pawnshop has a snap on mg725 for $150, but I'm leery of buying used.
Just remember that they consume lots of volume. How big is the compressor tank?
Sent from my SM-G920V
That will work for a little bit until the pressure drops. There are really good 3/8 impacts that are pretty wicked too.
Remember to pick up an oiler and oil.
I tried an 18V dewalt and it would take a lug off my daily driver accord. I have a $35 12V Kawasaki impact that worked better than the 18V Dewalt.
The Kawasaki is one of those wind up and pop type. Got it to use working on ATV engines.
What cordless impacts are yall using?
Lately I hear great things about Milwaukee. Both power and price. The M 18 fuel system is great that's what I have. I had borrowed a snap on system and and after that I was hooked. About the only air impact that use now is the 3/8 because the angle you can get into tight places
i have a a 3/8 snapon impact and works great but i always use my 18v dewalt impact on mostly everything.
Milwaukee 18v Li-ion 1/2" Impact. 450ft/lbs of torque! Worth every penny. Removes lug nuts without any issues. I only use my compressor for airing up tires and blowing dust off and the occasional cutoff wheel work.
This x3! I have the same one. Have only used my air impact 2-3 times over the past year since I got my cordless Milwaukee impact. I've even found myself using it to remove bolts where before I would have used a ratchet. I'm amazed at how long the batteries last and how much work you can do with them before they need charged. I just need to get the 3/8" drive one yet.
Sent via signal flare
http://smile.amazon.com/Bare-Tool-M...12&sr=8-2&keywords=Milwaukee+18v++1/2"+impact
That it?
How long do these batteries last (as in before you have to replace them)?
After trying that Dewalt 18V impact I figured none of them would be all that great. I bought two new Dewalt branded batteries for $100, and with brand new batteries the thing still wouldn't pop off a lug nut on an Accord.
Really .. I just took off sea salted lug nuts off a 7 with the 1/2" 18v dewalt.
Sent from my SM-N910P
This is the one I had. Figured with new batteries it would be good to go. It made a lot of noise, but didn't have much power to it.
http://smile.amazon.com/DEWALT-Bare...=1448912188&sr=8-3&keywords=dewalt+18v+impact
I have one of these that I bought simply because sometimes I HAVE to have an impact when removing clutch nuts and flywheels when I'm in ATV engines, and it serves the purpose for those, but the wind up and clack takes forever trying to use it anywhere else.
http://smile.amazon.com/Kawasaki-84...448912263&sr=8-1&keywords=kawasaki+12v+impact
That said, the Kawasaki busted loose the lug nuts that the Dewalt couldn't handle. Wonder if I just got a bad/worn out Dewalt?
Hmm yea that's the one I have . 300lb. There's a 160lb version also.. Works great for me .I took 2 cj7 apart this summer . I deal with a lot of rust stuff as u know. I also have that 18v dewalt screw impact that thing built my whole house with. on a Plus side it yellow. I got to have everything yellow.. 😁 I would look into that 20v dewalt . 1200lbs would break anything. Lol
Perhaps what you are asking is how long is the total life of the battery ? I hear around 2-3 years with the milwaukees. As in eventually you will need a new one. But I have no experience as to if that is the norm for lith ion batteries.
