firefighter736's Build Thread
I finished the outer floor on the passenger side
Decided to tackle the biggest body project that I have - the bed floor and rear support. I have a ton of more detailed pictures to make a nice writeup on the process (I haven't seen one yet) but I'll keep it short and sweet in this thread.
I had to remove 50-75 spot welds. I did this with a Harbor Freight spot weld cutting bit everywhere except for where the floor meets the sides. I had to use a cutoff tool for these as they were too close to the bed floor to get a bit into.
Test fit
I did a real number on the inner wheel tubs removing the floor so between that and a little rust in that area I have a couple of hours work coming up next weekend to fix that before I can put the floor in permanently.
Good work. Large sections are much more gratifying than the small intricate ones. Keep it up.
I really could use the motivation, haha. You look at some of the things and it just seems so close yet so far away from being done. I have made progress though:
Spotwelded the bed in and ran the 8 weld beads at the joint between the outer floors/wheel wells and bed floor.
After I got the bed nice and secure I took a sawzall to the dented drivers corner
And I was pleasantly surprised at how well the new corner lined up (with a tiny bit of trimming here and there). Here it is screwed in place. It would be spotwelded HOWEVER my spotwelder decided to take a dump on me and I called it a day.
I have a few more small patches to do and I can finally start on some body work on the tub.
Haven't had much time to do anything with all of my big summer projects at work kicking off and with some pretty major house projects going on as well. I've been piddling and got my heater box completely revamped with new heater core and new Blazer motor. Hopefully get the tub done before the end of August so that we can get some paint sprayed before it turns cold.
Frame is at a friend's who is going to fix the rust in it. He's waiting on his new CNC Plasma machine to show up (Friday, hopefully) and I believe my pieces will be the first run off of it.
I sent you a little note in my thread. Boy, we had to dust the cobwebs off of this one! I'm sure we all understand work and home life impeding jeep progress. I had hoped to be at Sandblast this year but it looks like it's next year is the new goal. You wanna car pool there?
I've been working on the Jeep but just haven't posted my progress. I have taken a break from body work and focused on getting the frame fixed, axles rebuilt, and other little things.
I pulled the engine and axles off the frame and had the frame sandblasted.
I had spotted rust in the passenger side frame near the rear hanger and was worried that sandblasting would reveal more damage. Luckily it didn't.
While the frame was at my friend's getting repairs I focused on rebuilding the axles. Here they are when I brought them back home to work on
And here they are after new bearings, U-Joints, seals, ball joints, brakes, and a lot of grease.
My friend took the frame and fixed the mounts and the giant line of rust in it. He also went through and rewelded all of the (really sloppy) factory welds in the frame.
HX8bUDTDbZleXV6ERKO2ofeUMjShHOl652ugXM852PZaa9pEA9DDD7YhWEGjE9MSn1bSUMJEePqYo_RiEgRlX94tLsvrxTwayDS4PklLueGGvLfbO2csZyXYFcK7SAzuFeSrBPcA6IT5Q7E-kSjfWMGM4pafeiHXB9KHnuf723Lziw7-CnsIBxUAfgRHmTKd41v5DWwopVYVgAjQlG64jKta3ux0qqI5367WniC_tovtKdbzCZd_9eSgq1BfWHGFZ7oYDuPzNk5quDx5m5YF0TkONpSaP7qIT34o44BJHHQT5RnOK-jSGSPN2KDe1P4Jp2xzgP_C7t145MPM_6X13fpw8_c-DHjFc-fhkpmwGhfP-OWqC2JmQPQHotB27tb1ryH50kAo4jmlZ2sQVeTwOu30vsnFARqPdo8YCXZFj6ZdyP27308nLILlcXXPOetig8TaPu40qVMYRhG2c-O2fla8NGlBom3wIA8SL2zuVJD0bRaZ3Zf9Q35QbTdrETwHU350z3Ry2LQENyXi6il4_GX5VZpXDPpTqtzoDPQRZkk=w1808-h1356-no
ugMGflwf6mZOdBzp1E4CqW7NIaTR7dOSTOFqdMJJctb7zamXagA1oePvSC40AcGGLJ6CmR9mOH5Qs5zEw0u4yTSSouBS7DqtPA_XZf3-ytXwDCodhhF5A7u4BAjc6c0cMeThshhDV3sVEMxwtwVFpulyAhm7uLVIEgTtQrCTpmCSF4ZVpHa4r9PKGFrHVD_AI0mDDwul6LJcXnQeYyhkC75SOiGuXQsadgXVkHjv8Ea6_ZUBL1hiq73QMlLH_vzu0Mj6FGI7PWSb_IM9B84vxsR228vV2cTSSkAta-gWE_7rzi6Af3n-i-yEc_OZ4mR_99iVY7YSb-D6K7hOgG9ShAXWAiAhGa3CYSAIBoqjC02iqChIBrW272pNTS-B7EUMy9Lm19swGF3DneH7w9F7rjZqepQeHTAZPUFerrWEXsfsndj_IG1LbuNWGVdSFrYvkp8d6d802BlUT4FBGYrCKGbCfGfnr1KeMOdKMHJO5aWy4r26waSJZ4aqj2EfTGquKl3pujVsSzaykKR3cN50MUCwXB08FFF2BW6j4GqH-R0=w1808-h1356-no
LoDj2H8Mykmjqkw7BCKzsDbDldOi2405_-Zv5bZIyRIwfcSKzbMngq6H9IWAGpl-za1WfNuZ11N-zwUbldOay1i0AwEzaQDjJy9ciK9CIchpvmJlu9Li9fjHwWLFS2qU2bzt7gr0Z4pbgVn1CXipJqTvSc_s3zhE5iW9U-aWIDsaC0vohkAUrCbWfFQNrazo_r_My3yafhIcIHheRINZTADZCg7giuXBspSACj-HgH4QO9mlBUTk_hY_iX64L-4mrM4AwfTNQtxs6JDQnks7aTYg-jnDAhML4KxjEK2JhtrfrCjr5gbF9_57zTGUjfaAJsTxx4izcGcGZZNCImYA4KjAoOQgz1reSoI3yl6jkByJL0hFuJ5JJB7BeYh9jONegXLV4FUZLVJcnLhtweFQB6x9e6mGNdP9KL6pbtN37A-VTj7z6Hz6uoiSpGo7CV4ZWaKss3TaQqV_a3t-PmhVrIz8n7D-r2FdeEa0_2NPoL4te81kYyzaa1dpfFrT7jDtP6iFLmJCsT-MnpweZizvvmkCH5Df3ZxF7lqkCLAYNF4=w1808-h1356-no
MBzeIzpTkaLbXq97RjlUYsZhxmaT42fSlD1WLJzY-3ENr4jTwjr77rR3T0-KUJLLUTv4qduYdHmTDF4TymFOJHkq3oMoVNewqq2m-K_7vejfRWBN6pmT87G0uwH8w7wdT1E6a7fGxe0fhMiqJfnYxbODFV0ZOUI1hc6RYQKmj-L4kzomEJJ418SnxgDXh4IaX4ZWAsn23qebxNE_QLj6z4W9H8qL5Ka6y60HgMshZcVr74cLgRe82o5lGj6ekaeJlvYusyVMwxciY7oufiQoEA49vKpH68h6fRVfNzToh7p6cF5QzUBJO4NgMqQhFGevWP6fQbCcrItTEjyAWeD4g1mhCN0hVqNvYV-N9dFyyRGD_CSbrX_hzxglWVM32_1HrBLjTqBb1-dIFsB-NjOyFAxkVKHeMUHwYTE3dZm_y0ygunfVBzmMS92K_C5tVKGDBIiQfNEJvg-gN1g56fpASwfjnV5eUUlq0w9XussVpN8Bau7lcd61DfpQkLGl-iBIU8ocdLHJXEMQALPFCwzPMb8OFUUT1-oIp1oCxooEsTY=w1808-h1356-no
I had the wheels blasted and powder coated.
3Bwf8W3uIMoSOQwO-XmSa-iYHQGKzUYjMv9uOsaXW72sw5kRAA2K_r0wkj1NU_Q9MOAXYLGfjgMV6PmplzWymp4agzomF_i5C_jDSnuPb3N9_AFfhYfVgyEuXKFWLPVyNI0K4OgB0EbYEa5glByFipAKXA-hOaJ8V411cZRxn2D5EY9nL6Y-RT9Yf09z9_9UYE3d6vrnH76_xdAo03DNZgCJQxUu7e700EyT5gPUv6tWNScFu5JelUUKKV74FAtyCp2vIggXDCa26Pw85jT2CkPnNkAzqOAgiMAYEHvBg4O43XptAbpg_6MjHsIh_brs1qyA4xmE_jyMBix72-C1wP9y0BtjFGMR0ZqH-i0mYHzsuDRnrfek2lxoPEvLv6BPA1ul_kI_zIFYLO3JjzA-xXQgpG200DdZh39CKtejO1VPPLCPlDVKe7WxPneiSejjmSS2e2fe-JZziipGXiYzCxkLQw2QUubs5iNmZfE48E5e3EbyW1iW0hIa_AHowBQMomlJGmX55xcPn26h7RdhCcxsWxKsEjihXUS5iLtUZWc=w1018-h1356-no
And then today I took all of the parts I've had sitting in the basement for 6 months and put them on the frame.
Sorry for the massive photo drop tonight. Just trying to get caught up.
Now the focus will be on getting the tub prepped (still a little welding to do) and painted.
You my friend are getting some work done! Looks great so far.
Haha, thanks Matt. It sure didn't feel like progress until I got the axles on the frame this weekend. I'd love to make more progress in the next month or two and get this thing in paint!
