First scrambler build!
That's one heck of a nice start. You really need to start your own build thread for this fine project. I don't NEED another project but if you are serious PM me. TN is not too far.
Well this thread started as my build thread...a year ago. I got the jeep home today and am overwhelmed. I own my own business and really don't have much spare time for a project like this. I had planned on finishing some items but not to this extent. I'm going to take a few days to think about it. As of now I'm over $15k into the build including the price of the jeep. I know I won't recoup my money if I sold the project but might consider a trade for another cj.
My bad.
I have at least that much money in my build and it's at about the same stage as yours. It's hard when you do it right.
"Relax and breath"
Take some time to think about it
I think like this twice-a-day and three times on sundays
Good luck with whatever you decide !
I've got a local body shop lined up to paint the remaining body parts. Hope to pick up everything this weekend if weather is good and move it to my shop. No point it crying over spilt milk...just want the jeep done. I'd honestly lost interest in it over the summer ( mostly because I was so busy with work) but I'm getting excited again to get my hands on it and at least have it back home...even if it's in pieces.
How close does the tub paint match the other body parts paint? Just curious.
Alright so I guess I'm committed. I've taken the body back off the frame to check all this work. The underside of body and frame has been painted with por15. Does anyone see a problem with me brushing on some black paint over it like the tractor supply tractor paint or similar. The Por15 is very dull looking and I think a little thin in some areas.
Por15 is a hard coating that is not UV safe. It needs to be painted over to protect it from the UV (turning a dull black, black version is one of the things that happen with the UV). You must sand it good so the paint will get a good bond otherwise the paint will peel.
Okay...I guess I need to give this some thought. Will it be fine to leave as it is? With the paint being on the underside of the jeep I can't see it getting much sunlight especially with it being garage kept.
As in how close is the new paint to the original paint color? The tub is the only part that's been painted so far
OK. I was just wondering how the front clip paint matched the tub, since different shops were doing the painting work. Since its not painted yet, moot point :thumbsup::wave:
I guess we'll see after the rest is painted. The guy I'm having finish the paint ( who I tried to hire to do the project from the beginning ) said it shouldn't be a problem matching the color. I've got the can with the paint code so it should be just the same as if the original guy had to go buy another gallon of the paint.
I hope it turns out to your satisfaction. That color might not be too bad to match up well but even the same paint code paints can look different if parts are painted at different times and by different people. Prep work differences, atmospheric conditions, paint thickness...and more can all play into the final color.
Thanks..I do too. Unfortunately there's not much I can do about it now
I'd really appreciate some advice on wiring from those of you that have done similar projects. My jeep was in great shape and 98% factory so the harness wasn't hacked up. Both harness are in good shape...just need cleaning. I considered buying a painless kit but don't know that it's worth the extra $$. I am doing away with the factory carb and emissions so I won't be using some of the factory wiring.
From what I hear on por15 it should be ok under the tub. The UV dulls the color some. For the wiring I highly recommend getting this wiring schematic http://www.ebay.com/itm/320481571115?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT. It's pretty accurate and much easier to follow than the factory manual. If you have questions take a pic, post and we'll help what we can. I've wired the cj7 and the current cj8 project with the painless and it worked well. If you have good wiring it's your call on stripping the old tape and re-taping things together. If you need the some dash light sockets let me know. I just put a speedhut speedo cluster in the cj7 (hopefully will drive it by the weekend) and did the speedhut on the cj8 project.
That's great! I ordered one so hopefully it makes the process a little easier...now I've just got to get that dash painted and I can start
So I'm thinking about buying new fenders. The fenders from the jeep are in decent but one has a small amount of rust on the inner side. Anyone just buy new fenders rather than spending the time trying to do repairs? If I go this route I want to make sure to get good quality that will line up right and isn't cheaply made.
I bought new fenders on the cj8 build and they needed to be adjusted (to put it mildly). Had to drill new holes (to mount to grill). Pass fender was way off and affected the grill and hood. My originals were pretty bad so I didn't have much choice. If yours have a little rust where you can get to it you're probably better cleaning them up rather than new.
