- Bedford
- NH
I am starting to wonder if Jersey's stretched body would go on a JK frame... hmmmm....
The patch panels will be welded solid, no way for anything to get in between. Then I think I'll POR 15 the underside, line-x the inside, and paint the exterior orange to match the cowl, fenders and hood.
If you did that in Louisiana it would turn into cancer in one year.
I would use epoxy primer. Por 15 doesn't have the greatest bond and is hard (and brittle). Epoxy has a very good bond to the metal and has a window for painting where it doesn't need sanding. Also the epoxy can be top coated usually within a hour or two (check with the tech sheet) to get a better bond between the epoxy and paint. I've used it on my work trucks and shot the paint (on the dry side). When I wet sanded the paint because it was thin I sanded through the paint to expose the primer (can see through the paint, probably about 75% paint, 25% primer) in sections. Have used the trucks for 3 yrs. and I live in Cleveland, Oh. with all the salt and rain no break down omer, no rust. No peeling of the paint where it's thin and the primer is exposed. This stuff really has a good bond and holds up to the weather. Here's a youtube of a test on the bond I'd like to see you do this with por 15. https://www.youtube.com/watch?v=-yA8q4K-_Bo I use Kirker, but I would believe most name brand epoxys are about the same (different manufactures have different set up times etc.) http://www.kirkerautomotive.com/images/PDF/ENDURO.pdfThe patch panels will be welded solid, no way for anything to get in between. Then I think I'll POR 15 the underside, line-x the inside, and paint the exterior orange to match the cowl, fenders and hoo.
