Small block ford swap
That is true. You would need an adaptor at the bellhousing. But you would not need one at the transfer case.
Plus you get the steep first gear (4. something to 1 instead of 6. something...) in addition to OD.
But I think your plan is solid and should go together well.
I noticed from novaks web site that the 176 is about 3" shorter than the sr4. The more mounts move the engine forward a few inches. The transfer case will be about 4"closer to the front then... maybe maybe not. Would this paired paired with a 2.5" lift make the front drive shaft too steep? The woman says she's buying me one for my birthday.
If you say so... I don't know of the top of my head. It makes sense since the SR (and the T4/5 trannys) has looooong tail housing that holds the shifter. I would think the t18 would be even shorter than that.
But if you use a clock ring between tranny and transfer you will add an inch-ish back.
Hard to tell on driveshaft. Your lift will offset some of that, maybe an inch. So with no hard wheeling you could be fine.
As an FYI, I used Carolina Driveline to lengthen/shorten my driveshafts (I went to a double cardan type rear) and I think extending the front was $100 and that got it back to me looking like new with new spicer u-joints.
The t18 with the adapter is almost exactly the same length as the sr4 with that tail shaft. I'm not worried about having driveshaft length changed I'm mostly wondering if angle was on for the u joints. I really wish there wasn't clearance issues with the front shaft with the engine in a stock type location. If it were centered I could run the mustang shaker intake I have.
I used these: http://www.summitracing.com/parts/sum-g9035/overview/
which are for a late 80s - early 90s f-series 5.0
They come in a summit box, but are made by pacesetter.
They have 5.8 specific set also. It appears only the passenger side is different, which is not where I had issues anyhow.
I then used summit tube sections, a summit h-pipe kit, a couple overlap band clamps and dynomax turbos to build the rest.
As for driveshaft; if you aren't going to wheel it hard, you could probably extend your bump stops a little and it may clear fine with engine in stock position.
Last, unless you have something very custom going on, driveshaft angle will not be an issue for you. And maybe not length either.
Did you have to change shafts with the more mounts? I ended up buying them and my novak tcase adapter is on its way
The Contour fans are a great option when you get that far. The stock mechanical fan will hang below the radiator, and on mine it hung below the front cross member too.
I did not have to change driveshafts because of the motor mounts at all. I did it because my overall driveline became about 3 inches longer relative to a fixed point I picked on the frame.
So I likely would have HAD to address front shaft length. But my rear would have probably been OK.
But with that much more power, and I am working on 4:56 gears and 35s now, I wanted to go to a CV type rear driveshaft.
I decided to see if my 97 351w engine could benefit from a hone or a re ring so I pulled the heads off. Still has hone marks in the cylinders. The man I bought the engine from had pulled it from his dad's rotten f250. He said it had 76000 miles on it but it wasn't very dirty or worn at all. He said he never hauled anything but the occasional round bale or a small amount of lumber with it. So after some fresh paint and buying some gaskets I'll be all set to start the carb conversion. All parts have been removed from the 85 engine I had. I found out the distributor is a mallory unilite self contained unit. Not sure how good they were but I'll probably try it before purchasing a msd kit.
Those roller blocks live long lives if they are even sort of taken care of. So, good news for you. Your 85 block bored at .060" over is pretty much bored to the max it can be, and sometimes they have heating issues when at that dimension. So I think you are going the right way even with 76k baseline.
While you are poking at things, how do freeze plugs look? It is way easier to change them now....
And, Mallory is now part of MSD. So they will have your spare parts when/if you need them. Do you have the whole Mallory distributor? Or just the unilite conversion in an older Ford original? Doesn't make much difference in this application, it will work well either way. The unilite is just another not-contacting way (like magnetic technology) to trigger spark events. It will work with the duraspark, pertronix, msd, mallory (if you have the whole unilite set up) - whatever control box you want.
Making nice progress!
It's the whole distributor. I thought it was the duraspark. I'm glad because I prefer the timing curve of the aftermarket stuff. Freeze plugs look good. I'll probably have the engine rebuilt after a few years anyways. Maybe a slightly better cam, better pistons... I'd like to get the jeep finished first though. I still have a long, long way to go though. I'm hoping to have it completely ready by memorial day 2017. I know my new air compressor is making things go a lot quicker than before
Anyone on here relatively familiar with the autolite 4100? I've got one I want to use but it was on a 390 engine. It's the 480 cfm model I'm going to assume the jets are off and would like to get a general idea of what I should be using before I start to rebuild it.
Sounds like you are good for ignition.
On engine - The 5.8 you are looking at, both year blocks you have actually, are relatively low compression. The 97 if stock will have hypereutectic pistons, and compression is like in the high 8's. Unless someone changed it, the cam in the 97 block is the same roller hydraulic unit that would have been in the 5.0 explorer. Just short of .500 lift and good for low end torque with good power over whole curve. Probably good for a light jeep, but for the cost of timing cover gaskets, you could grab a used mustang cam of some ilk and pump it up some while it is apart using stock lifters, pushrods, etc.... You would get bigger HP/Tq numbers but they will likely be higher in rpm range.
Saving money... the stock piston/cam set up using stock heads with a little thinner head gasket to bump compression a bit, will give you 200-and change horsepower and 350-ish ft-lb torque low in the rpm range. That is plenty enough to tear up driveshafts and axles in a CJ before modifications begin.
For carb - the Autolite is very good for a driver and light off-road, very hard to modify to be good in steep angle off-road situations. Was advanced for its time when produced and generally once it is set up the way you want, it will stay that way and run well. They don't require a lot of fiddling. Ford and AMC used them as stockers on lots of stuff for just that reason. Its a good carb. They have a small bore and large bore version just like the 2100 does, so you can check which you have.
I have to think a square bore like this will run better on the split plane intake you have. I would think a spread bore design may cause cylinder mix variability issues in mid throttle operation.
The 85 engine that I scavenged parts from looks like it was rebuilt, used for a little bit then swapped for a diesel. It has aftermarket .030 valve relief flat tops. I haven't pulled any yet to see what make our what condition
Don't know if you have considered it, but a Ford ZF5 might be an option. Too long for a CJ5/7, but a CJ 6/8 should be able to accommodate the extra length. There is an adapter available to fit a D300 TC too.
I thought it would be too long for it. I love the zf5. Or was the adapter for fsj applications?
After some research I found that overall with it's adapter it's just under 8" longer than a t18 combo. May still be too much.
