My De-Rustification Project
X2 tff
Edit oops just read GTs comment fully, mine didn't cross me off yet :/ (yet)
After doing a bunch of household chores I got out to the garage to start on my list planned for tomorrow. So tonight I got a few little things done. I connected the speedo cable to the t-case. Got the clutch linkage attached and hooked up. Cut the pucks for the underside of the body mounts. I had to order the big flat washers, so I will finish those and tighten it down once they come in. Also hooked up all of the hoses to the evap canister. Went to hook up the fuel fill and vent hoses for the 20 gallon tank. Turns out that I need to go get a bigger hose clamp.
I forgot to mention that I also added lock washers to the engine mount bolts and gave it a quick and dirty alignment. Even looking at it you could tell it needed one.
Does anyone know where to hook the spring to? And where to hook the throttle cable to? I guess I forgot to take a picture of the hook ups before I took it apart.
Update. Got the throttle cable hooked up. Just wondering about the spring now.
So far today, I installed the throttle cable, installed the seats, wire brushed then painted the MC and booster (hated looking at the rust), installed a smaller air cleaner that will actually fit the space, installed the new filler and vent hoses and mounted the fuel filler. No adapting needed. Stretched and used as much of the metal of the filler neck as possible though.
Started to put the front clip on for good. The pass side went well. The driver side not so much. I need to get some longer bolts and some nuts as the nutserts are just spinning for the top two bolts. I am getting frustrated and calling it "beer time". I have spent a lot of time on it today and need a rest. I also need to cut a new puck for under the radiator. I will probably need a new/longer bolt as well.
By the way, more fun news. After moving the body, it would appear that I have to realign my doors. Yippee.
If you didn't move the windshield frame the doors should be the same. Must be a lot of flex with the fiberglass body. Coming along nice. At this point it's all down hill.
I'll trade you completion dates:rolleyes::cheers:
I have passed my planned completion dates a few times already. And recently bumped it to March (not set date - just the month). At least we have had a couple of nice weekends in Feb or I would be in even worse shape.
Dain, that thing is starting to look like a real Jeep.
For every one task we complete, we create 2 more.
I missed my deadline by 3 months so for and over budget by about $20,000.00
I will keep that dollar figure in mind. Especially when my wife talks about what I am spending. I am nowhere near that. Thank goodness. But I am NOT going to add up my receipts. I don't really want to know. The plan was to keep it under $5K. I think I have. Thank goodness bolts don't cost a lot. But welding was the only labor that I farmed out so far. I might have a couple other jobs done for me at the end. Pinion seal and reworking my exhaust are the two I can think of right now.
Oh yeah, and welding the frame tie-ins for the rollbar.
Dain? How are you trying to fool? :) 16 pages? I've been following every one. Do you want me to start adding it up for you? You know I'm just making fun of you right.
Haha. I am only trying to fool myself. That is all.
