My De-Rustification Project
Best set of tools I own, tap and die set!
I've been using the same Hanson Tap and die set for over 30 years. You just can't buy tools that good anymore.
I'll put a tap in my cordless drill and just go around and run it through all the holes.
I'll put a tap in my cordless drill and just go around and run it through all the holes.[/QUOTE]
If i did that, l'd cross tap the treads.
This is my 2nd build and I haven't cross threaded one yet. Use a slow speed and don't tighten the chuck too tight. Then again we don't salt our roads in the south.
Well the day gets better. Trying to bleed the brakes. Not going well. How long do I have to pump to get fluid to start coming out of the rear? Dang it. Nothing. I am getting a little fountain in the reservoir though.
https://vimeo.com/159720563
Oh and the two front bleeders are stripped and the vice grips would not get them to budge.
Open a rear bleed screw, pull the mc cap off and walk away. Come back after 10 min or so and hopefully you'll have to fill reservoir. If you wan'the a little faster loosen the rear line at the top of prop. Valve. Let it bleed til it comes out of that fitting. Tighten and go to line exiting valve at rear. Loosen that fitting let gravity bleed til it drips. Close fithing then go to closest rear wheel. Bleed that one then go to other. It that doesn'the work i'll tell you how to get the piston to ctr. In the valve. If off to side will block fluid to rear
Use mapss propane tank and heat caliper at bleed screw then try vice,grips. May take 2, tries. It breaks up rust and expands caliper where bleed screw screws in to.
The heat was definitely in the plans.
And thanks. I have the bleeder open and waiting to see.
Sometimes you have to break it down in sections, gravity bleeding is like power bleeding (without power). Gravity doesn't always have the push for the entire line. In my life only Had to break it up once.
Calling it a night before I break something in frustration.
Amen to that. The tools I've bought vs the tools the old man have are night and day. He bought most of his stuff in the 60's, and it's SOOOO much better than even the top of the line stuff now.
Not sure if your interested but I usually change all my bleeder fittings to the ''speed-bleeders". I believe they have a Dorman part number.
They use a small check ball in them so you can bleed the brakes by yourself. I've always been happy with them, even if they are a little pricey.
Sent from my SM-N910V
I will look them up. I have not had a chance to see if the gravity bleeding did anything.
Had a rough day. I had to say goodbye to my oldest pup. Nothing jeep related today.
I haven't even looked at my brakes yet but I plan to change all four of mine to speed bleeders.
So sorry for you. Losing a dog is one of the hardest things you can go through. Our thoughts are with you.
Thanks guys. I appreciate it. Been through it a number of times. Never easy.
