My De-Rustification Project
And here is my throttle cable hooked up to my carb. Anyone see anything wrong? I am revving at about 1600 per my tach. I ca press down on the piece that the throttle cable is attached to a little and get the revs to drop some. But since it is not the idle screw keeping the revs high, I am not sure what to adjust. The actual throttle cable does not have an impact. I took it off completely and no help.
I wanted to accomplish something today so I decided to install the hatch I got from Randy. Surprisingly, it went well. I still need to screw it on, but here goes.
Marked it trying to center the sending unit in the box
Then I cut
And here it is
Dain check that the end at the pedal is in the hole properly, it may not be seated fully.
Do you mean this one? I don't think it has to do with the cable or pedal as I completely removed it and it was the same. When I removed the tension spring on the carb, it got faster.
Could the fast idle linkage from you choke linkage possibly be holding your throttle partially open.
Battery terminals showing 11.81 volts. The post on the back of the alternator to the battery ground is showing 11.78
Is this with or without the engine running?
I believe the alternator and battery connect to the starter solenoid terminal, so the minor difference is understandable. But only if it's not running.
Hmm. I think it was while it was running. Yeah, I believe it was. I will try again in the morning while off. Key to acc? With the Jeep not running, would the alternator put anything out? I know I would get a reading from the battery, but would not expect anything from the alternator since it isn't turning.
Oh and for whit it is worth, it is a brand new battery
So got a lot of yard work done and decided to mess with the Scrambler. Started on the reverse lights. Fuse looks good so I took the plug off if the switch on the transmission. Putting an ohm meter on the two terminals gets me readings. Around 28 based on the lowest setting I had. When I pull the shifter out of reverse it drops to zero. That should be telling me that the switch is good. So then I ran a jumper between the points on the plug. No lights.
Replaced the fuse for fun. Still nothing. I guess I will see if the wires are pulled out at the plug and go from there
Noticed that the 4wd light does not come on either and they are in the same harness. I wonder if there is something going on there. I will follow that harness back up to the engine and see if I can find anything wrong.
Well, I found an orange wire not connected. Plugged it in and now the 4wd light comes on. Yay. But still no reverse lights.
So with the Jeep in reverse, the power is making it through the switch and into the white wire in the plug. I tested it past the connection of that small harness into the main harness in the engine bay and there is still power there. I will keep tracing it back
Update. Found the problem. It is at the harness connection at the rear. Jiggling the connection got them to light up. Great. I got all of the lights working now. Just gotta get those dang brakes bled.
It sure doesn't take much to makes us Jeep owners feel good does it Dain? :)
No real progress on the brakes other than finding out that I know have fluid at least making it to the splitter at the rear. I noticed a puddle there after pressing the brakes a few times. So that is a little progress.
Decided to move her out into the sun. And clean the garage a little. That allowed me to get to the front bumper and winch. So I just installed them. Not sure if I needed to have the front bumper on to pass inspection, but it was good to clear a little room. Installing the rear bumper would really help. But I need to do some modifications to mount that so I will need some more time.
By the way, the idle was purring at 650 today. Go figure. I guess she liked being outside. And now the gas gauge works too. Woot.
:thumbsup: :thumbsup:
I've been busting my chops on my own Stump Jumper project and I decide I just needed to do something else today so I started cleaning up my shop. Sometimes you just need to take a break.
Today was yard work then it was supposed to be housecleaning. Since my wife is sick in bed, I decided to play with the Jeep. Mostly good news today.
Then ....... I tried to use her own power to turn around and go head first into the garage. I just found out that the gears are not engaging. Crap. When we had the engine out we replaced the clutch. Something must have gone wrong when reassembling. Darn it. Darn it. Darn it.
It is always something. Why did I have to wait so long to try to move it on its own? I really don't want to drop the transmission on it. Grrrrr.
