- Ashburn
- VA
Ground for horn? Of course that's what I always say for any of your problems![]()
First thing I thought of as well. Hopefully they tested that. I will make sure.
Always something...
At least you're legal!![]()
I think the starter can stick in low voltage situations which you seem to have had. Check out your alternator grounds and connections. Do you have the resistor wire on yours?
Should be an easy fix. Replace starter solenoid. You might want to make sure it's not a sticking ignition switch, but that's pretty rare.
Pic number 2 gets my vote. Cold beer always gets my attention[emoji106]
When you have the other Jeep connected seems you are reading it's charging system. I don't think you should need to ground the alternator but it won't hurt. Sounds to me like it's not charging. Unless the exciter wire is not energizing it.
