My De-Rustification Project
I am wondering if I just have the t-case in neutral. I would rather feel stupid for doing that.
You might feel stupid but I'll bet you will be happy! Let's hope. That hatch turned out good! Bumper and winch look good too. I have the Q9500 on mine- so far so good. Seems like a good deal for the price.
Agreed. My wife splurged when she got me the 11000. Definitely a good price. They have made improvements. But I like mine so far.
Turns out the t-case was in neutral. Yay! Happy and stupid. Good combo tonight
I much rather feel happy and stupid than sad and pulling the tranny again. I hope when I find my problem I get to feel a little stupid too.
Made progress on bleeding the brakes. Since I saw the leak at the crossmember over the rear, I felt good that fluid made it that far. I tried to tighten that connection and start on the rear. Fluid flowed freely. Did one wheel until it ran pretty clear. Then did the other rear wheel. My son was in the driver seat pressing the pedal. Then checked the front. Both front flowed great. Still had the leak at the connection and tackled that. I think it is good now.
So the pedal felt really good. Then I turned it over and now the pedal is really soft. But I did notice that I let the reservoir go a little too low for the rear and it might have sucked in some air. Oh well. I will redo the rear. But feeling much better about it. Should have it done by the weekend. Maybe I will tackle it tomorrow night. Then I can get it inspected.
Getting closer. I can smell it. Or is that brake fluid and exhaust? ;)
You sure are getting close. Keep it up! Oh, and don't forget to clean that oily engine! I'd hate to see you do all this work for it to catch on fire :eek:
Thanks. And thanks for giving me something else to worry about. Glad You got a new fire extinguisher especially for fiberglass (marine).
Your at the point that you can use the vacuum pump or probably gravity bleed. You beat the brakes, congratulations. Need to see a pic of you behind the a wheel ready to drive.:bacon:
Yep. Gonna turn the Jeep around and let gravity help me. Hopefully you will get a pic of me driving it soon. Soon.
Ok. So I got A LOT more air out of the rear brakes. The pedal feel is much better. But it still won't allow me a super hard stop. So probably have more to do. Took it for a test drive. (Sorry. No one was around to take a video.)
Also noticed that I need an alignment. My eyeball alignment was not enough.
Still a good day. And I spent some quality time with the Scrambler cleaning all of the oily handprints off of it using Simple Green. Worked really well.
All tucked in now.
Good job! Congrats!
Thanks. If you see it straight on, it is obvious that the stock springs it is sitting on definitely have been well used and are shot. They have the Jeep Lean really badly. But hopefully those go this weekend.
I do plan to have someone else replace the rear pinion seal and swap in the one piece axles from my old rear. I don't want to screw that up. The same shop will be welding in my frame tie-ins for the roll bar.
Looking good!
Thanks Randy. It took a village. And you were definitely one of my assistants in this project.
Goes to get inspected tomorrow (along with the alignment). Fingers are crossed.
Drove it to the shop for an alignment. Stopped and got gas first. Haven't seen a gauge read full in a while.
When I dropped it off this morning I noticed the horn did not work. No Beep. Crap. Won't pass inspection. So they are seeing what is up. I heard a click in the relay and a whimper from the horn. Probably the horn is gone. No worries. I can deal with that.
They just called me and said I will need new u-joints on the front axle. I wonder if I can swap the ones from the axle I removed.
Ground for horn? Of course that's what I always say for any of your problems :)
