My De-Rustification Project
It passed. But there are a couple things to deal with. They could not get the steering wheel to be aligned. Not sure why. I can deal with that later. What bothers me is that on the way home, I noticed that the voltmeter was showing around 10. As I pulled into the driveway, the radio died. I cut the jeep off. Won't restart. Battery is drained. Gotta figure out why the alternator is not charging the battery anymore. It was the past couple of weeks. Grrrr.
Always something...:rolleyes:
At least you're legal!:woohoo:
Ugh. So I go out to test the alternator. Hook jumper cables up to the JKU. Fires right up. While cables are on, the voltmeter in the cab reads above 12. Good. Disconnect the cables. Still running but the volts drop to 10 again. Hook up my multimeter set for volts (200) and get a reading of 16 between alternator and neg on battery. Just between the posts of the battery, it reads 25.
Turn Scrambler off. Won't restart. But now, the starter keeps trying even with the ignition off and key out. When I go to hook up the battery cables, it tries to turn over. The starter solenoid seems to be stuck on.
Should be an easy fix. Replace starter solenoid. You might want to make sure it's not a sticking ignition switch, but that's pretty rare.
I think the starter can stick in low voltage situations which you seem to have had. Check out your alternator grounds and connections. Do you have the resistor wire on yours?
Was researching while away from the house. I do not have a dedicated ground for the alternator and may add one. What resistor wire are you referring to?
Swapped out the solenoid. So that part is fixed. But still not getting the alternator to charge the battery.
I just want to drive this thing. Please!!!!!
Using this diagram, I am looking to add a dedicated ground. But of course I don't have a bolt to go into the only bolt hole I have on the back of the alternator.
I need a second set of hands out here so that I can see if the voltmeter changes when I ground the alternator housing.
So when I ground the alternator housing, no difference. I am only getting 11 something of volts across the battery terminals off of a fresh jumpstart. With the other Jeep connected via cables, I am at 13 something. And of course the volts drop and drop once the jumper cables are removed. I checked the resistance of the alternator housing to the neg on the battery. Not running, my ohms are at .3 or less, which is what the meter runs anyway. When running, the ohms are 2.73. So according to the pic above, I have a wiring issue, most likely grounds. But I hold a ground wire to the housing and there is no difference in the resistance.
Do I through a new alternator at it? Tighten the alternator belt? Ugh. Giving up for the night and getting a beer.
By the way, test painted part of one of my glass doors to see if I like it better than all white.
Vs.
Pic number 2 gets my vote. Cold beer always gets my attention[emoji106]
When you have the other Jeep connected seems you are reading it's charging system. I don't think you should need to ground the alternator but it won't hurt. Sounds to me like it's not charging. Unless the exciter wire is not energizing it. Are you sure you have a good battery?
Picture #2
Exactly. I assume my readings are the JKU when the jumper cables are hooked up.
What is this exciter wire that you are referencing? Testable? I will just get a new alternator if that will fix it. But I don't want to buy one if it is not broken.
Around here almost any auto parts store can test a alternator. I certainly don't claim to be an expert but the way I understand it, the alternator basically need s to be turned on when the engine starts and this is what the exciter wire does. Its just a 12 volt battery source provided by the ignition switch to energize the alternator. So if the ignition is in the start position I think the exciter wire should be reading battery voltage. If I am wrong will someone please correct me.
If I end up needing a new alternator, does it matter which amp output I get? I see 63 and 78 amp versions available.
I don't think so. In fact, look into the one wire alternators. From what I understand they only have the battery wire and don't require the other wires to operate. I have never used one but would certainly look at them.
I have a one wire alternator. It's great! When you start the engine it isn't running, so I indicate 12 ish Volts. Blip the throttle above 1200-1400 or so once, the one wire realizes its running and starts charging 14.2 ish. Less wires = more reliable in my book. I do wonder why we ever got away from one wires. I am sure there is an energy efficiency thing going on.....
