My De-Rustification Project
How easy is it to convert to a one wire alternator if i am already set up for the multiple wire style?
It's been a while, so I would have to google and refresh myself. I needed a "high amp" for my elect fan and winch, so I shopped for a while and picked up a factory new 140a powermaster that was set up for either. It works great.
Well. Alternator failed the bench test. New one is in. I went with a higher amp unit. But still multiwire.
are you thinking now all those tow home times maybe were alternator related? I can't recall what you finally ended up with, but then it was the tear down, so just trying to see if maybe that was it.
I supposedly solved that with a new pickup coil. But the alternator has been putting out low voltage for a while. I have not seen the needle higher than 12 in a very long time. It probably fried the cell in the prior battery. Could an alternator fry a pickup coil?
Was feeling good about the progress and drove the Cj to Home Depot to get bolts to install the bumper.
So two big things to do. Swap out the leaf springs for the old 2.5"lift leaf springs. These ones on it are shot. The pass side is past flat.
And I know this Scrambler is lower than it used to be because I keep banging the top of my head on the top when I lean i. Ouch. Gotta swap those out very soon.
And I need to swap in my 1 piece axles. Can't forget that.
And weld the frame tie-ins for the roll bar.
Dang it. The list is still long. At least I can drive it. ;)
And much like Dennis posted on his thread the other day, I need to thank soooo many people for helping me get through the last 8 months. I definitely could not have done it without this great group of people here at CJ-8.com.
As I told BW a month or so ago, I will be upping my membership to a lifetime one as it has paid for itself many times over by now.
Yep, I'm a lifetime member for the same reason. It's paid for itself. I will still make donations from time to time.
Glad your charging system issues were not to complex. You're in the home stretch!
Could not stand the look or the fact that I banged my head on the top whenever I leaned in. So tonight I installed the front half of my 2.5" lift.
Front passenger fender before
After
And lovely squat at the rear right now.
Hopefully I will get the rear done tomorrow.
Over 3 inches of difference for old 2.5" springs. Those stock springs were worn and was inverted on that corner.
After
Why? that is one sexy Carolina squat ;)
Got the rear lift done tonight. Looks much better.
Before
After
Sitting nice in the garage
Now for the fun part. So most of you know what happened to me when cutting off the body mounts. Well, while the loft was easy to install, I got the worst of it.
The bruises are the lift's fault. The burn on my bicep is from solder when I was working on the rear lights harness.
And this was from the cut metal of my sliders that are along the wall of my garage. Since I had to work in the garage tonight due to rain. My pant leg is shredded and full of blood now. Oh well.
