If you think about it, the cable goes from the equalizer in the rear up to the front wheel well, through the frame, so the distance isn't that much. If you go up to about the same distance as the transmission, loop it over to the seat (would have been more distance with RHD vs. LHD) and you aren't too much different in length(again, RHD)... the only thing I see though is mounting it and having it be able to be yanked up... you really want a LHD version of the RHD one of these.
I am sure it could be made to work, but figure that they designed this for the RHD side, so working on the opposite side, in theory it would have to be backwards (facing the wrong way), or not able to be reached due to seat or console interference.
